Results 1 to 8 of 8
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    Default Ryker on a trailer?
    Has anyone hauled the Ryker on a utility trailer? Was there any problem making the break over at the top of the ramp? I noticed that Tractor Supply has a 6 x 8 utility trailer with a 4' ramp that looks like it might work.
    2019 Ryler Rally , Shock Yellow
    Quote Originally Posted by Tslepebull View Post
    If this is the one with the vertical attached ramp …. my experience was not too good …. BOTH of the securing devices fell apart on the same trip …. I fixed it with a solid 8 or 10 inch bolt using a lock-nut ….. The replacement parts from tractor supple was $30.00 EACH .….. good luck …. Mike
    Sep 2019
    New Jersey
    When I bought my Ryker I showed up with 5x8 trailer, Ryker didn't fit. If I had 6x8 trailer it would of worked out.
    Active Member Dragracer's Avatar
    Oct 2009
    Lecanto, FL.
    I used this trailer I built to haul my wife's Spyder, and my Ryker to the Keys.
    Calling an illegal immigrant an undocumented worker, is like calling the corner drug dealer an unlicensed Pharmacist.
    2019 900 ACE , Stock Black
    Jan 2015
    southern WI
    I've hauled ours on our 7x14 open trailer. The ramp is 5ft long I think. I load and unload with the trailer hooked to the truck, and the tongue jack cranked way up to reduce the angle of the ramp. I had no issues at all. Anything you can do to reduce that angle is key. Use the tongue jack, park the trailer wheels in a low spot, park up against an embankment, boards under the back end of the ramp....etc....
    2021 RT Limited
    2016 RTS , Pearl White
    Jul 2020
    Coral Springs
    @Dragracer, what’s the dimensions of your trailer. I’m looking for a trailer to haul my Spyder and my husband’s Ryker. The Ryker doesn’t have a windshield so it can go backwards. My Spyder has saddle bags (F3-T).
    Dec 2020
    Mesa, AZ
    it will work fine. The 6’ is actually about 6’6”. I have the 3 pieces luggage set on Slingmods, So I made an extension of the rear tailgate latches of a few inches and it works fine.
    Apr 2021
    Ky
    I prefer an adjustable hitch on the tow vehicle. I raise the tongue as high as possible to smooth out the angle at the top of the ramp. I also found piece of 2x4 at the bottom of the ramp kept the noise from dragging. Don’t forget if the front wheels get too close to the front of the trailer the spoiler will hit the front of the trailer.
