Results 1 to 14 of 14
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Default squirrelly on the highway
    The Ryker seems somewhat...unstable on the highway. At least that is my impression. I have to hold on for dear life when going over bumps or changing lanes. If I recall correctly, the F3 was more stable. Your thoughts?
    2019 Rally , Black
    Mar 2016
    Payson, Arizona
    Read the Do's and Don'ts for new Spyder owners, and relax your grip on the bars.
    Sep 2019
    illinois
    I turned my front shocks down from #3 to #2 on my Ryker rally. It made a huuuge difference out West of you on the rough Boone county roads.
    Durham,Maine
    I think on the Ryker it's direct steering, no power assisted, so the steering would be a little touchy and you would have to sit back and not over drive it! Just a thought!! Good luck
    2012 RTL , Pearl
    May 2009
    Connecticut
    My Rally and F3 are about equal on the highway BUT on off kilter back roads with rough spots the Rally demands your attention more!!
    Sea Doo GTI-SE 90 Jet Ski!!
    Ft Pierce/Lk Placid
    Unless you are on newly resurfaced roads, they are unfortunately like that. A road I go on, where car tires ride, the road is smooth, but the middle is rough though, a 2 wheeler can ride one side of the lane or other, but with trike we are screwed.
    I don't experience this so I can't really comment. But I'm wondering about your alignment or tire pressures.
    Have you messed with your front shock spring pre-load?
    Jul 2010
    Las Vegas, NV
    We have had to align Rykers, so you might check that. As Ron said, check tire pressures. 1/2 pound difference is something that you can feel!
    Joe Meyer
    Quote Originally Posted by cptjam View Post
    I raised my front tire pressures to 20 psi and it made a big improvement. I am going to try 21 psi and see what that does.
    May 2009
    Connecticut
    I have my Rally front at 20- At 22 pounds it was more gittery ? I'm 195 pounds- It will be interesting to see how you react to a higher pressure.
    Apr 2015
    Chicago
    OK, I will check the tire pressure. I will need to figure out how to adjust the suspension. As far as mechanical things go, I'm like a monkey using a stick to eat ants.
    2019 Rally , Black
    Durham,Maine
    Quote Originally Posted by Rogue Hawk View Post
    Thats a good one!!!
    2012 RTL , Pearl
    Seriously!?
    Jan 2009
    austria
    mine one was "hopping" when I got it - they changed the swaybar to the stronger Version and ist OK now - on the back I use the FOX with the "hardest" Position ..
    I also have more pressure in the fornt and rear tires .. for me the Ryker has a better handling than my "old" Spyders (GS / RT )
