Results 1 to 8 of 8
Thread: Air Chuck
    May 2014
    Benson, NY
    Default Air Chuck
    Here's what you need to get air into the rear tire of your RT. https://www.harborfreight.com/Extend...tor-63571.html
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Dec 2015
    NE Ohio
    I use a flexible air hose with a straight clip-on or screw on chuck end. I'll have to try your idea to see if it works.
    Default Oh yeah..!!
    Have used it since I got my spyder and recommend it always...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Northern Kalifornia
    Quote Originally Posted by Bensonoid View Post
    Yep, that be the one. However, in addition, while you are at Harbor Freight, buy all three of the connectors and one of the quick connectors. Put the one you usually use on the air chuck and keep it stored in your spyder, and keep the others as standbys. Reason being is that on the road when you need air and find it, you never know what type connection you are going to run across. If you have all three you should be in good shape. By the way. Harbor has a connector that is supposed to adapt to al three styles, but I haven't confirmed that by trying to actually making it work myself. I'm a spooky about these "one size fits all" things.
    Mar 2015
    Fritch, Tx
    Most decent bicycle shops have these for about a buck a piece. Combine that with the longer air chuck like in the link above (or get a really good one at NAPA and a trucker's style long guage) and you are all set.
    Those who say " I can't" will always be right.
    Durham,Maine
    Got one LOVE IT
    2012 RTL , Pearl
    Mar 2018
    Ontario ,way up north
    That is what i have used for years ,and yes it works on the spyder.
    2018 RTL , dark blue
