Results 1 to 5 of 5
    Apr 2015
    Grand Forks, ND
    Default Oil Change 1330 SE6 - drain engine or trans first?
    On a 2018 RT should I drain engine or transmission first?
    Jim
    Jun 2019
    Deltona FL
    Most people do tranny first because it holds the least amount & is easier access...…..
    Jul 2014
    Mint Hill, NC
    Makes absolutely no difference. When you loosen the crankcase plug it will begin to leak or slightly stream out. I stuff paper towel into the void to the rear of the plug on the belly pan to keep oil from getting on the pan and then onto the garage floor. When you break the seal on the filter cover you will probably hear some more oil drain out of the clutch cover plug hole, so don't reinsert the plug as soon as it initially stops draining.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jul 2019
    UK
    I do the engine side first, while its draining I remove the mirror and side panel. Unscrew the oil filter to let air in so it drains too then drain the transmission side. Go get a coffee while it all drains down completely. Replace everything and it's job done. Don't forget the oil!
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
    Dec 2013
    Quote Originally Posted by PinkRosePetal View Post
    ...... Don't forget the oil!
    Good plan! And that last bit (quoted) certainly is a biggie! It's almost as important as remembering to put the drain-plug/s back in BEFORE you start re-filling with fresh oil!! But, if you're anything like everyone else, you'll probably only ever forget to do that the once!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
