Results 1 to 25 of 36
    Nov 2008
    Canada, Ontario
    Default Oil change 12 months, YES or NO
    Hello all,
    I have a 2018 F3 LTD. I had an oil change at the end of the season last year at 5000 kms. I thought BRP recommended an oil change every year irrespective of the mileage. I currently have only 10000 kms on it at the moment. I contacted my dealer for an oil change and he said the next service is at 20000 kms only.
    What do you make of this?
    J
    2018 F3 Limited black, dark
    Florida Swamp
    Time to start changing your own oil and ignore the dealer?
    2019 F3-S , Black & Silver
    Johnson, Vermont
    I change oil by mileage only. I ignore the yearly recommendation. I don't feel yearly changes are required.
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    I usually go by mileage as well, not time. But then this is the first vehicle I've owned with such a long change interval. I'll probably change mine yearly regardless od mileage just for my own peace of mind.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Mar 2019
    France
    Lots of oil now is long life so mileage only.. That's what I do on the bike and cars we have
    2009 GS SE5 , Red (Ferrari Red :) )
    Apr 2012
    Florida
    I change my oil yearly. The dealer does it. I never put enough miles on it, 9300 for oil and filter changes. I get a full service every June. I usually have 5,000 miles on it. One year it was only 3,000. It never hurts to change old oil sooner than it needs to be. Tom
    2020 Petrol Blue Metallic RTL
    The extended oil change times and mileages also have a caveat.
    My 2014 manual states if I do not exceed the recommended oil change mileage (9,300) to change it at least once a year. Many here do change it out more frequently. The dealer either did not want to be bothered with it, OR, does not know what the proper procedure is. Either way...I would suggest another dealer if possible.
    USA
    Quote Originally Posted by jbim View Post
    Hello all,
    J
    Manual says 9300 miles or annually. Be a darn shame to void the warranty because your dealer, like so many others, is ignorant of their product. My 2018 RTL is plagued by warranty issues, right now I'm suffering with the second bout of parking brake failure. Hope your's isn't in the defective batch!
    h0gr1der
    Page 109 of your operator's guide says every 15,000 km or 1 yr, whichever comes first. H0gr1der makes a very valid point about risking your warranty by not following the oil change instructions. Yes, the current generation of motor oils are much better at protecting engines against acids and corrosion than some of the old stuff we grew up with but, were I you, since you don't roll 15,000 km/year I would change or have the oil changed annually immediately before laying it up for the winter. Then you'll be ready to ryde the very first good day of the next year.
    Default opinions....
    As long as you ryde it go with the mileage recommendation...though I don't go that long as I ryde hard and change at around 5,000 miles..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Houston
    I can tell you first hand that when engines fail, BRP does ask for records of proper oil changes before approving the claim for a new engine.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Durham,Maine
    I would go with miles or year which ever comes first!!! Oil and tires every one has there own twist if it feels good do it!!
    2012 RTL , Pearl
    Mar 2015
    forrest above Reno, Nv
    I haven't gone 9300 in a year--- usually between 6 and 7K. Thusly I change oil and do winter maintenance just before I put the up for the winter. Same with the old, slow V-Max. I NEVER let the vehicle ( heck even the snowblowers) sit idle for a season with old contaminated oil. Some folks think that it's ok to let your soft bearings and steel parts sit in acid contaminated oil that may be 4 or 6K miles old------NOT ME.
    Lew L
    2014 RTS , Circuit Yellow
    Active Member Rookiespyder's Avatar
    Jun 2017
    Hanover Ont Canada
    Once a year or every 15000 km for us Canadians which is 9300 miles.
    2015 RT Limited
    Default Oil
    , Oil the product has become better...… When it's " clean " it will last longer than what was, when sold 10 years ago …. But it's a fact that Oil also breaks down over time after it's been used and thus " contaminated "...… I do my own maintenance and it's costs me about $30.00 to do my oil & filter.... ( and it could be the same price for you w/ Rotella Full Syn oil )… I'm careful about my money, but to me this is a no brainer.....jmho …. Mike
    Vermont
    My dealership changes the oil yearly, when my spyder is in hibernation( Oct. to April). It is easier for me.
    I have a spyder with a "1330 ace engine" and 26,000 + miles on it.
    I use full synthetic oil 4 T stroke Motorcycle oil.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Oct 2013
    rome new york
    Agree!!!
    May 2013
    Edmonton Alberta, Canada
    I do mine just before putting it into storage for the winter every year regardless of how much I'm under the mileage threshold.
    2014 RT-Ltd , Cognac
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    If you don't hit the stated mileage -- I would definitely change oil/filter out yearly as printed in the OM. Better to be safe than sorry when it comes to warranty.
    Joe
    2023 F3
    Jan 2015
    southern WI
    I'll be changing mine this fall before storage. I'll have about 8k miles on it for the season by then. Once a year for me now with the 1330. I used to change the 998 more often.
    2016 RTS , Pearl White
    Sep 2019
    ON - Ontario
    So I'm new to this, I picked up my new Spyder 2 weeks ago, I have a total of 600 kms so far on it. So should I change the oil before I park it for winter? I'm hoping to keep riding as long as I can but I live in Canada and winter can come over night lol
    Sep 2019
    South Dakota
    Yes, change it annually if you don't ride much! I just purchased mine with less than 1800 miles but is a 2013, just purchased oil, filters, coolant and brake fluid to change next week before I put into hibernation for the winter.
    Cheap insurance - and isn't it listed in the maintenance schedule anyway?? Along the lines of scheduling an oil change annually, or at the indicated milage, whichever comes first? For the minimal cost & effort, why not? It's certainly gotta be cheaper than replacing an engine or gearbox...
    Mar 2019
    Central SC
    Quote Originally Posted by Frankie69 View Post
    Unless you know the dealer/po changed it before you got it, I'd change it as soon as possible.
    2014 RT-S , Orange
    May 2013
    Indiana
    Deanna
    Deanna,
    I live south of you.The temps here are definitely trending downward, and the daylight is getting shorter. Can't imagine what it's like in Vermont. Got an appointment on Oct. 18th for my '15 RT Limited's "end of season" annual service, and oil change. This will be the last annual service for it under any type of warranty. My BEST warranty expires on April 2020., while it's in for it's winter nap.
    I've had zero mechanical issues with my Spyder. Needs a rear tire before next riding season(15,000+ miles).That's why I'm on the fence about looking at a 2020, even though my 70 year old hips are having a hard time with the seating position on my '15.
    Mike
    2021 Marsala Red Metallic RT Limited
