Results 1 to 11 of 11
Thread: Password
    Oct 2013
    rome new york
    Default Password
    Upgraded to Windows 10.
    Forgot my password anyone know how to recover.
    Thanks in advance
    Jan 2017
    Bavaria, Germany
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Is there another login account on the machine to log in with? If so, you can change the password from it and then log in to the account in question. This page has an outline of what that looks like: https://hetmanrecovery.com/recovery_...-or-laptop.htm
    If you have set up a Microsoft Account when it was set up with WIN10, then you have a chance at doing it thru MS: https://support.microsoft.com/en-us/...count-password
    If not, you are gonna need a program (like the one prev listed or on the page I listed) to recover/change the password with. You will boot from USB/CD with it and change from there.
    Chuck
    Apr 2019
    Florida Swamp
    My suggestion is probably not going to be very helpful, but I think the best thing you can do is format the hard drive and dump Windows, then load a Linux OS on it. In case you have not figured this out yet, I really hate Windows.
    2019 F3-S , Black & Silver
    Dec 2015
    Oakley Utah
    Quote Originally Posted by bmccaffrey View Post
    Thanks in advance
    Okay, I'll bite...what password are you talking about? Does this have anything to do with Spyders?
    2014 RTL Platinum
    Oct 2013
    rome new york
    Looking to recover my password for spydelovers. Using my phone. But need for my laptop. Sorry for confusion
    Nov 2015
    Chardon, OH
    What kind of phone? If iPhone, go to Settings, Passwords and Accounts. Navigate to the spyderlovers line. Tap on it. Password is on the next page.
    Doug
    ”Freedom is not a loophole”
    Oct 2013
    rome new york
    Quote Originally Posted by Snowbelt Spyder View Post
    Samsung s6
    Oct 2013
    rome new york
    Seems admin should be able too help???
    Dec 2013
    Anthony can probably help, but if you have your password saved on your phone so that you can access the Forum via it anyway, I think it'd be a fair bit quicker & easier if you changed your password on your phone.... AFAIK, it doesn't matter what type of smartphone it is; I've changed my passwords regularly on a variety of Samsung phones, altho mine have mainly been Samsung Notes...
    Still, if your password is not saved on your phone so that it'll default into the password field, you will need Anthony to help, so you'll hafta send him a PM or a msg via the Contact Us link down the bottom of every page; once he gets that PM/msg & satisfies any ID concerns (which might take a while, possibly 24 or more hours by the time all the back & forth is done?) & then gets the time to actually do it; he'll be able to over-ride your password with a default password; which he then has to send to you; and then when you get that msg and log on using the default password, you'll hafta go into your profile and change that default password into something else that's meaningful/useful to you.....
    If it is saved on your phone, you can go to 'my profile', find 'Forum Actions' in the menu bar up the top of that page, select 'edit profile', the select 'Edit your email & password' - if you've saved your password for the Forum in your phone, it should default that password into the 'enter old password' field; then you fill in the 'new password' & the 'confirm password' fields; and then hit 'submit'. And this same process is effectively what you'll need to do if you hafta go to Anthony for a default anyway, except that in that case you'll need to manually enter that default password into the 'old password' field.
    Hope that lot's of some help, sorry I can't do more for you myself, but that's how it is. Good Luck!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Idaho
    Isn't there a forgot password link on the login page?
    2014 Copper RTS
