Results 1 to 25 of 28
    Jun 2019
    Texas
    Default Cramped seating for driver?
    I went to my local Can Am Dealer to look at the 2019 Spyder RT LTD. I sat on the seat, put my hands on the handlebars and felt cramped!! I'm only 5'-10" with a 30" inseam! I have a 2018 Yamaha XMax Scooter and do not feel cramped on it! The lumbar support seat hits my ass end... and I feel that I need to slide back another couple of inches... and my arms are bent in too far, I feel!
    Is there any suggestions about any seats that may have more room for the driver? I almost never carry a pillion, so that's not really an issue! Someone suggested that I spend the $750 and get the Can Am Comfort Seat and get possibly another 1 - 1 1/2 inches more room! Really!!??? After spending almost $30K on a new RT LTD... Can Am says you ave to spend an add'l $750 for a seat??? Why can't this be an option when you buy the bike... you know, "Upgrade to the Comfort Seat for only $200 more"?? Even if you order the Comfot Seat on the original bike... they charge you the same price as if you were to order one later!! What's up with that??? Again... looking for suggestions!!
    Yes, I sat on the F3 LTD! LOVED the seat, the add'l room for you arms and your legs!! So, I would like to buy an RT LTD with the seating and floorboards of the F3 LTD... with all of the extra room!! ha ha ha
    Jun 2017
    Crossville TN
    We have am RTL also I am about your size a little taller, we always ride 2 up ( or else ) I purchased the pegs from Lamont to help me stretch out a bit and just lean back a bit and enjoy the ride. I am still playing with the angle and distance for the pegs, but they helped. I do not know if he previous owner upgraded to the comfort seat or not. Hope this helps
    Dave
    2013 RT Limited
    Lamonster FBB with larger gripper pegs
    Value Accessories dah mount
    Custom Dynamics High Mount brake light
    BRP passenger arm rests
    Jun 2010
    Las Vegas
    You were lucky with your current bike having a seat that was just right for you, but people spends thousands of dollars on motorcycle seats everyday for all models of bikes. The Comfort Seat at $750 is about half the price you’d pay for other aftermarket Spyder seats. They are built for the masses asses and yours must be different! I had a Comfort Seat on my RT and it was awesome for me, I’m 5’10” with a 34” inseam.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Stock seats have NO Lumbar support …. so don't expect one to be there...… If you don't fit onto a stock seat ….well how big is your butt ??? ….. not trying to be snide …… Mike
    Jun 2019
    Texas
    Hi Mike... by "lumbar support", I'm referring to the back portion of the drivers area that is raised up 4-5". With my butt against the back of the driver's seat, I still feel cramped! I don't know if an add'l inch or inch and 1/2 is going to solve that issue! I'm 5-10 and about 255#, so I'm a larger fella!! A custom seast may be the only way to get comfort!! Thanks!!
    Oct 2017
    Las Vegas, Nevada
    Quote Originally Posted by pflasch View Post
    Feelings are personal but for example, I am 6'-4" and 200 lbs with a 35" inseam and don't feel cramped on my 2017 RT, plus I always ride with a passenger and we use the stock seat. Based on my own experience it's hard to understand how you could feel cramped and I/we don't. In fact, I bought my RT over the F3 because the design of the F3 puts a little piece of fiberglass that juts out from the body right where my knees are and felt painful right there in the showroom. I'm betting you just aren't accustomed to your RT yet. Use it more before you start changing things.
    If you really want to start changing things, don't change the seat first, not because I'm arguing with your feelings but because you might get better results with Tri-Axis handlebars and LaMonster's forward foot pegs. Tri-Axis handlebars could move the bars "away" from you and relieve your feeling of "my arms are bent in too far," not to mention possibly being a more comfortable position for riding. The pegs will let you stretch your legs on the highway. I don't have the Tri-Axis because I personally don't need them but I'll vouch for the pegs. These fixes aren't exactly cheap BUT they'll never be a **waste** as a new seat might be. You could end up changing seats several times trying to find one you like and each one will be a big expense -- and you might still being unhappy with it and end up STILL needing the Tri-Axis handlebars and foot pegs.
    2017 RTS , Blue
    Active Member Huked's Avatar
    Mar 2017
    Watford City, North Dakota
    I Just got a 2019 RTL. I am only about 5'9" and I was very cramped on the stock seat. It put my foot so far forward on the board that I had to lift my leg to get to brake pedal. I test road the demo they had with a comfort seat. I would not have bought the RTL without that comfort seat or a plan to get another seat. I do not know if the seats are different on the older RT's, but the 2019 was a no go. I paid $500 after discount from my dealer to get the comfort seat with my new bike. I was told it was more than an 1.5 inch change, but I did not measure it. I will say it made all the difference in the world.
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    BRP Passenger armrests
    Baja Ron Anti sway bar
    Lamonster's upgraded BRP vibration damper.
    2019 RTL , Asphalt Grey Metallic Dark
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    I bought a Corbin seat for my RT. It is very supportive, what some call "hard" but it does soften some as you break it in.
    They totally custom built mine. Moved drivers portion up 2" and back 3". I am 6ft 6 inches and never carry a passenger,
    so the back seat area has been shortened. Hey I am tall and heavy, and it was just what I needed. They aren't cheap. but you get what
    you pay for.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Oct 2013
    Wood Village OR
    I’m about the same size and weight as you are and felt cramped also, I found a Used Comfort seat on Spyder Lovers for sell post for $200 and it solved my problem, I’ve put 42K on my RT the last 3 years; we are on a Coast to Coast and back trip as I’m posting this and the seat is working great. I have also added highway pegs and that helps to.
    2014 RTL , Black Currant
    Dec 2015
    Oakley Utah
    Ditto here. Was lucky and got a used comfort seat on this forum for less than 1/2 OEM price. 5'9" with 32" inseam. Cockpit feels roomy now. Wife has her own RT, so passenger seat room not an issue.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Quote Originally Posted by johnsimion View Post
    and think the triaxis bars should be standard on the RTL
    2014 RTL Platinum
    Northern Kalifornia
    You might take a look at 2019 F150. It will likely cost less and give you all the support and comfort you desire.
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Interesting info on seats. I do not have a spyder yet, but have ridden 2 wheelers for a very long time. I do not have a butt for riding bikes, meaning stock seats just don't do me any good. I have used stock seats, Mustang, Ultimate and E.D seats. For me the Ultimate was about the best. I currently have a Diamond seat on order for my ride. As many people have stated. Seats are made for the mass. It's expensive to find the perfect seat. Good luck to all.
    Northern Kalifornia
    Check with the iron butt riders, they'll give you an insight on the best after market seats out there.
    Sep 2018
    Carson Valley NV
    Jarvis, I have a buddy that last I heard lived in Pahrump retired from the Navy. Known as "fuzzy" go guy if you know him.
    Need to do more traveling
    2018 Limited , Grey (Looks green to me but title says grey)
    Jun 2018
    Pahrump NV
    Lonestar, Sorry for not responding. I guess I speed read and missed this one. Pahrump Valley has about 39k spread in an area about the size of Las Vegas. Short answer is it doesn't ring a bell, but if he rides any type of bike, I have possibly met him.
    Bob
    Sep 2018
    greensburg,pa
    I also have the Comfort heated seat(Free courtesy of BRP) and it helped alot! 5"11 30+ inseam.
    Go here and they show pics to show how much longer the comf is.
    https://www.utpr.com/spyderrtcomfort.html
    2018 RT-L , Blue
    Dec 2015
    Oakley Utah
    Buy a used comfort seat and install it yourself. That's what I did...for about $165 with shipping
    2014 RTL Platinum
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    I went to my local Can Am Dealer to look at the 2019 Spyder RT LTD. I sat on the seat, put my hands on the handlebars and felt cramped!! I'm only 5'-10" with a 30" inseam! I have a 2018 Yamaha XMax Scooter and do not feel cramped on it! The lumbar support seat hits my ass end... and I feel that I need to slide back another couple of inches... and my arms are bent in too far, I feel!<snip>
    Strangely enough, I did the same thing, with the same results, on Saturday. Sitting bolt-upright, elbows down at my side. Claustrophobic.
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Ultiumate makes a seat that is 1 1/2" longer/butt setback. I actually ordered that and had to return it. It sat me back too far. I'm 5'8" with 27 inch inseam. But for MY thinking, Ultimate makes a really good seat. Who makes the 'best?' Only your butt knows.
    Jun 2018
    Pahrump NV
    I would love to find a used one, but unable. I rode about 50 miles today and that's about it for the stock seat. I'm 5'9" - 210 lbs, 30" inseam but my seat is not hacking it. Anyone have a comfort seat for an RT they don't want no-mo, let me know.
    Thanks, Bob
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Is the "Comfort Seat" the one that comes stock on the RT Limited? If so, I have one (barely used) I'd love to sell. It's off my 2014 and barely used.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Jun 2018
    Pahrump NV
    Quote Originally Posted by OverHillAndDale View Post
    I would just measure like this: https://www.utpr.com/spyderrtcomfort.html I would assume that if the measurement is 18 inches, then the answer would/could be yes.
    Dec 2015
    Oakley Utah
    No, the comfort seat does not come as standard equipment on the RTL
    2014 RTL Platinum
Tags for this Thread
