Results 1 to 5 of 5
    Member Dodgedad's Avatar
    Mar 2015
    Canada
    Default 2020 Can am Spyder rt ltd backrest
    Does anyone know yet if the backrest from my 2015 would fit onto the new seat of the 2020. Thx
    Feb 2012
    Spring City,Utah
    Just a guess but probably not. The seat has been redesigned.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    The 2020 accessories catalog shows 2 different part numbers.
    2020 RT Limited , Marsala Red
    Mar 2015
    Canada
    Does that actually mean much, could it maby be a different bolt or something minuet like that
    Dec 2013
    The 2020 RT seats are 2 part seats, rider & passenger seat bases being separate; and the front seat is significantly lower than the passenger seat. All the RT seats for RT's from before 2020 have one part seat bases, with the rider backrest support going thru the front of the passenger seating area & fitting into the bracket underneath that spans about 1/4 of each of the base areas for both the front and the rear seats, altho the entire seat pan is one piece. Then there's the issue of how & where the different backrests work - the 2015 backrest itself is designed to support the rider in the small of their back, above the low but in-built lumbar support provided by the rise in the seat pan & the padding in the squab above; while the 2020 backrest fits between the 2 separate seats and provides support in a completely different way to that of the earlier seats....
    Your 2015 back rest is not going to be transferrable to the 2020 seat. Well, at least not without butchering the seats and doing some potentially really savage & ugly 'customisation' to make it fit.... which would be akin to trying to force fit a seat back taken from a Model T into a 2020 Mustang, only it probably wouldn't look as good as that!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
