Results 1 to 13 of 13
    Oct 2017
    N.E. Ohio, USA
    Default Oh no, another trailer question!
    I presently haul my 2011 RT from Ohio to Florida about twice a year. The trailer is a 5 foot six inch by 12 open trailer. (five and a half foot).
    My wife wants me to get a bigger, enclosed trailer. I'm thinking a 6 x 14 tandem enclosed. I do NOT want to go wider than 6 foot. So my question: does anyone haul a Spyder RT in a 6 foot enclosed trailer?
    Problems tying down?
    Problems with the door cables being in the way?
    Are newer Can Am Spyder RTs the same width if I were to upgrade to newer?
    I like my 5 foot 6 inch trailer because it is narrow. The bike just slips in.
    Thanks for the replies!
    Ride safe!
    2018 Spyder RT Limited
    Jun 2017
    Rapid City, SD
    6 by 12 Continental Cargo. A little over an inch clearance on each side of ramp entrance.
    HE>I
    2017 RT , Asphalt Grey
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Be sure to get a trailer with "V" nose, not a flat nose. You'll get much better gas mileage.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Jun 2017
    Rapid City, SD
    Quote Originally Posted by Grandpot View Post
    Wish I would have done that. It does have a rounded top though, which is nice. Water doesn’t pool on top so avoiding rust down the line.
    HE>I
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    I'd suggest a 6 1/2 x 12. The extra bit makes a difference. I have a 6 x 12 enclosed cargo trailer and my 14 RT won't fit. I've rolled the bike up the ramp but it was too tight. You could also remove the fenders but that's a bit extreme.
    Active Member WDAVEY's Avatar
    Jul 2019
    FL in winter, CNY in summer
    Quote Originally Posted by daz View Post
    I thought I had it made! I had a 6X12 enclosed Pace cargo trailer with ramp door that I used to haul my Harley back and forth to Florida. Guess what? My new 2019 Spyder RTL would not fit through the door opening! Too narrow by about 1.5". Turns out that the 6 foot measurement is to the outside of the walls, so subtract wall thickness, then subtract door frame, my spyder is 5'2.5" wide, aw shoot! So I now have a 7 X 14 tandem axle all aluminum enclosed trailer with adequate room all around.
    Jul 2019
    I thought I had it made! I had a 6X12 enclosed Pace cargo trailer with ramp door that I used to haul my Harley back and forth to Florida. Guess what? My new 2019 Spyder RTL would not fit through the door opening! Too narrow by about 1.5". So I now have a 7 X 14 tandem axle all aluminum enclosed trailer with adequate room all around.
    Active Member Gldwnger's Avatar
    Apr 2015
    Kitts Hill, Ohio
    Apparently BRAND makes a difference. My 2014 rt will fit in my continental cargo trailer.(6x14) About 3/4 inch clearance at the cables.Slow & easy going in and no problem.
    Apr 2015
    Grand Forks, ND
    Where did you find the wheel chocks?
    Jim
    Jun 2017
    Rapid City, SD
    Quote Originally Posted by JimboRTS View Post
    Jim
    Etrailer.com
    HE>I
    Jul 2010
    Las Vegas, NV
    They ride in the rain. Waterproof! Hold what you got. You could have it professionally detailed after every trip, and still save thousands! Better still - ride it!
    Joe Meyer
    If the inside DOOR width opening gives at least 1 1/2 in. clearance on either side ( of the fender measurement ) you can do what I did ( mine was only One inch ) ….. I placed wooden runners for the outside of the tires & screwed them into the deck of the trailer...… this will keep you Spyder away from the walls …. this is similar to what is in every Car Wash machine I have ever seen ….. as far as tie-downs, I posted years ago that placing a HD ratchet strap over the rear tire ( securing the ends to the floor ) will prevent the Spyder from moving at all …. and will not dent or scratch or bend any parts of your Spyder …. it's the way Transports of High dollar cars ( like Mecum Auctions ) do it in their TT units …… there pics posted on this forum of folks who are doing it this way …… good luck and ...………. Mike
    Sep 2017
    INDIANA, USA
    Default 7×16 Trailer
    Just my 2 cents. I use an enclosed trailer that is 7'×16'. WHY ? EAZY TO LOAD. Also have a nice area to stow away extra camping gear.....
    ps: the trailer is a 7×16 enclosed v-nosed Legend
    ENJOY YOUR LIFE WITH A SPYDER
