Results 1 to 13 of 13
Thread: Wobble at 45
    Jul 2018
    Colorado
    Default Wobble at 45
    I have a 2011 RTS with about 5000 miles. I have had the bike for about 2 years and wanted to improve the ride. So last week I added the BajaRon sway bar and Elka stage 2 front shocks and a stage 4 rear shock. I took it out for a ride up the canyon and the handling is greatly improved however now when I hit about 41 I get uncontrollable wobble until about 45 mph. I didn't have this problem until I made the changes. I made no changes to the factory settings of the shocks. If I have the sway bar ends too tight would that cause this wobble? I made the same changes to my wife's 2013 RTL and it runs great.
    Any suggestions will be very welcomed.
    Sep 2017
    Durham,Maine
    I would go over all that you did, and make shore you have every thing tight and in place! What are you running for tires, some are directional are they on the right side? To bad that you didn't do it in steps and test, but I don't blame you when you have her skirt off you want to get it all done!! good luck
    2012 RTL , Pearl
    Jul 2018
    Colorado
    Yeah that would have been the smart thing to do. I am still running the orginal tires. I know I should replace them since they are 8 years old. That is the next round of up grades. I never pulled the tires so they shouldn't be a factor unless the up grade magnified a preexisting problem.
    Sep 2017
    Durham,Maine
    Are they cupping yet??? Maybe the stiffer shocks are making you feel that!
    2012 RTL , Pearl
    Sep 2017
    Durham,Maine
    just a thought, or a tire out of balance!
    2012 RTL , Pearl
    Jul 2018
    Colorado
    Tires look pretty good considering. No noticeable cupping. I wouldn't think out of balance since nothing changed with them while replacing the shocks and sway bar unless doing so would enhance an out of balance issue from the old set up.
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    Are both shocks set on the same setting?
    Happy owner of 2014 White RTS - SE6
    Jul 2018
    Colorado
    Yes according to the QC tag that were on the shocks they are. I only made sure they were the same length. I figured the factory knows better then I on the set up.
    Aug 2007
    Greeneville, TN
    After being sure everything is tight and installed properly. I would ask, did you change the suspension height (front or back)? A change in height will affect alignment. A little change isn't usually a problem. You can also change the front to back angle with shock adjustment which may also affect alignment. The poster suggesting that by adding stiffer shocks you may simply be feeling an out of balance tire that you didn't notice with softer shocks, may also be onto something.
    Jul 2018
    Colorado
    Thank you for the information. I do know that the ride height did change with the installation of the shocks. I will work on getting the alignment checked as well as trying to find someone to check the balance on the tires. It might be prudent just to get the tires replaced while I am at it.
    Jun 2013
    East Aurora N.Y. U.S.A.
    My 2011 had the same problem. Tires looked liked new(Kendas). Had them balanced twice, problem persisted. Switched tires and wheels side to side(reversed rotation) problem gone. Put new car tires on front end of problem!
    Quote Originally Posted by mzirger View Post
    …. with your assessment - the worst of the Kenda may now be more evident with the suspension improvements …… good luck …. Mike
    western Colorado
    Sounds like tire balance issue since it happens at certain speed. Might be worth a try checking lug nuts for tightness. Also making changes could effect alignement. Just ride.. tires may be adjusting to the changes..
Tags for this Thread
