Fog \ daytime light combo
Just installed a Led combo fog/daytime running light kit from one of the vendors , fog lights come on when switch turned on , but day time lights do not come on when spyder is running . 2019 f3 ltd , any thoughts ? and one installed this kit , it the one with the daytime led C shaped.
thanks
Go it to work the day time running lights TRUN OFF when the HI BEAMS are on . Turned hi beams off daylight part of fog light goes on . NEVER would have guessed that .
Why not run with the High Beams and Fog lights on all the time? The only time I use the Low Beam is at night when a vehical is approaching me. I'm running HIDs for all 4 lights.
I had the EXACT same incident a couple weeks ago. The vendor wasn't aware of the correct function, but the MFR was. MFR explained it's a DOT thing..
