Results 1 to 4 of 4
    Mar 2019
    lakewood ranch fl
    Default Fog \ daytime light combo
    Just installed a Led combo fog/daytime running light kit from one of the vendors , fog lights come on when switch turned on , but day time lights do not come on when spyder is running . 2019 f3 ltd , any thoughts ? and one installed this kit , it the one with the daytime led C shaped.
    thanks
    Mar 2019
    lakewood ranch fl
    Go it to work the day time running lights TRUN OFF when the HI BEAMS are on . Turned hi beams off daylight part of fog light goes on . NEVER would have guessed that .
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Why not run with the High Beams and Fog lights on all the time? The only time I use the Low Beam is at night when a vehical is approaching me. I'm running HIDs for all 4 lights.
    Aug 2019
    Stoughton, WI
    I had the EXACT same incident a couple weeks ago. The vendor wasn't aware of the correct function, but the MFR was. MFR explained it's a DOT thing..
