Oil change - can I fill thru filter hole?
Good evening, I'm about to put the oil back in my 2013 rt snd I always wondered if you can pour the bulk of it into the filter hole instead of the dipstick hole. Thanks, mike
2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
Will it ever stop--NO
SpyderLovers Sponsor
There is no way I can think of that this would work. It is my understanding that the dry-sump holds only about 1 quart of oil. The reservoir holding the rest. Not sure why you would want to do it that way.
Just thought it would be easier/quicker, it's so slow putti g it in the dipstick hole
Get a large plastic funnel with a spout small enough to just fit the dipstick hole.
That's what I always do, I guess I'm just impatient and I was in the garage at night with poor lighting. Just gettin old I guess.
Has anyone ever thought about putting a hole in the tupperware so's you could get to the filter without removing so much, esp those dang mirrors. Thanks, Mike
Agreed. I've never had much trouble filling after an oil change. I think it would be much more problematic trying to fill a horizontal filter hole than a vertical tank.
There is only a few bolts and a couple of push pins to pop the whole side off mine.......... 2019 F3-S. 10 minutes at most to take it off.
Ozzie Ozzie Ozzie
Reason: Link
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Yeah that would be great and I love the F3 but I have more tupperware on my RT
[I] was trying to make my own but the magnets were so powerful and sensitive I broke most of them
Originally Posted by Peter Aawen
So you haven't fitted 'Magic Mirror Mounts' yet??
I've had them for a fairly long time now, and I still find myself just taking the Mirrors off & letting them jump back on for the helluvit, cos it's so quick'n easy! <snip>
Hmm, I have a couple of extra push pins left over, where all do they go. At least i dn run short. Thanks, Mike
How often do you change oil? For most people 4,600 miles or 9,300 if it’s a 2014, doesn’t happen that often. It’s just a few panels.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
The was my 19,000 a little late. I'm just used to my car where just just pour it in and it takes it as fast as you can give it to her. Just did one car and ready to do the next. Gotta change the fuel and air filter on the spyder yet. Might do the magic mirrors-heated seat and gas door and stage 2 this winter when I put her down. Thanks, Mike
