Removing dash blank on 2018 RT
So, I want to run a power line through one of the blank covers on the dash below the handlebars and I am having a problem removing the blank cover. I don’t want to break the cover but I need to remove it to run the wire. Anyone know the technique?
Is it the switch bock with the park brake etc?
The park brake on 2018 is on the handlebar. Bu on older RTs I think it is in the area you mentioned.
They look like they should pop out but you actually need to cut the "blank" out. I fitted a Switch for Driving lights and had to remove the whole assembly to achieve this without damaging the plethora of cables underneath. I have some details if you need them.
I put a rocker style USB outlet on our RTL. The cover in the middle between the fog light and heated grip switch popped out with much persuasion, but i couldn't get the other ones to come loose.
2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
The center blank has a round hole and there are two ways to get it out. One is to destroy it and two is to get at it from below. That requires removing the mirrors, side panels and some bolts to move the whole glove box so you can get to it. I suggest installing the USB outlet in the middle and any other switches in the other black spots.
If you're mounting a phone, try putting it on the dash and route the cable up through the windshield center mount.
Try searching on Youtube.
SpyderLovers Sponsor
Flat tip screwdriver, pry up. It will break. Once out, install new switch/USB, whatever. Joe
Joe Meyer
How do you route wires as the switch will need them.
