Page 1 of 3 123 LastLast
Results 1 to 25 of 51
    Nov 2017
    San Francisco Bay area
    Default Suggestions please
    Both the fuel level and engine temp gauges on my 2015 RT have been disabled in favor of using the digital display on the screen. Consequently I want to remove both and replace them with something useful and I'd appreciate suggestions. USB ports? Volt meter? Push to eject button?
    Thanks for any suggestions!
    Left Coast
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    Mirror Mount Turn Signal Indicator
    2015 RTL , Yes Pearl White
    Passenger eject button and warp drive indicator.
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    I put in a Volt Meter & a Digital Clock...
    2014 RT-Ltd , Cognac
    Jul 2010
    Las Vegas, NV
    Most folks put a clock and a USB. Pretty handy. Joe
    Joe Meyer
    Sep 2017
    INDIANA, USA
    Default Gauges
    My vote would be a 'Push to Pass' button. Second would be A button 'You SEE Me' so that Drivers Will NOT pull out in Front of Spyders.................
    ENJOY YOUR LIFE WITH A SPYDER
    Feb 2012
    Spring City,Utah
    I put in a Volt meter I got off ebay. It is 52 mm in size. I think it was under $25 but I don't remember now. Just ordered a 12 volt socket for the other side from JT's machine shop
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    Quote Originally Posted by Purple Guy View Post
    +1 Here
    2018 F3 Ltd. , Black/Dark
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    My '14 RTS came from the PO with a Voltmeter on one side, and an oil pressure gauge on the other. The USB ports are in the middle of the buttons on the "dash". Sometimes buying used has it's advantages, lots of stuff I don't have to add. On the down side, there's stuff I've removed - XM Radio, SMH10, flag holders. And now it looks like I'll need a new front caliper.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Dec 2015
    NE Ohio
    Quote Originally Posted by LeftCoast View Post
    Left Coast
    I didn't get fancy. I used a 2 port USB on one side to charge Sena etc and a 12V outlet on the other for my GPS. A clock would require separate power from the battery. I just used the gauge power, works fine.
    Nov 2017
    Quote Originally Posted by Little Blue View Post
    If I could get a couple of James Bond missile launchers those would be very handy.....
    Baja Ron Sway Bar
    Strobe Brake Light
    Nov 2017
    Appreciate the feedback everyone. I ride with an Apple Watch so I’m not sure if I’ll put in a clock or not. The dash clock as everyone has noted must run on some sort of “there are 400 days in a year” cycle it runs so fast.
    Baja Ron Sway Bar
    Strobe Brake Light
    Default choices, choices
    A trip to the autoparts store is always fun.... volt meter, altimeter, usb/lighter, clock, oil pressure are some that come to mind....
    ​2012 RS sm5
    Nov 2017
    This prompts a question from me. I'm not good with a wrench as has been well documented in some of my other posts, but oil pressure gauge vs the warning light on the panel. Is the gauge redundant?
    Baja Ron Sway Bar
    Strobe Brake Light
    Ah yes...many years ago we referred to those lights that came on when it was to late as "idiot lights"....a guage would let you know your oil pressure and condition. Of course now they do have the added feature of shutting you down when the light comes on to save you....volt meters let you know how your chargings is going and your consumption of said volts. Check out others you would like to watch in action.
    ​2012 RS sm5
    Mar 2008
    Hesston, PA
    I put a volt meter in the left side and air pressure gauge in the right side (air spring/bag)
    Active Member Docster's Avatar
    May 2017
    Perry Hall, Md
    Left Coast
    Easy suggestions. What would be most useful to YOU? USB ports, voltmeter, compass, thermometer, oil temp gauge.......?
    2011 Spyder RT-S
    LtCol, USAF Ret
    Proud Patriot Guard Rider
    2011 RT , Yes Blue
    Very Active Member cruisinTX's Avatar
    Mar 2015
    Fritch, Tx
    Flux capacitor?
    Those who say " I can't" will always be right.
    2014 RT Limited , pewter (magnesium?)
    Nov 2017
    Quote Originally Posted by Docster View Post
    Not sure, seems like a USB port could always be handy as I run my sena’s paired to my phone but I also carry a spare battery for it. I guess I might be leaning towards a voltmeter for the other one.
    Baja Ron Sway Bar
    Strobe Brake Light
    Nov 2017
    Quote Originally Posted by cruisinTX View Post
    Flux capacitor?
    Spare dilithium crystals for Mr. Scott?
    Baja Ron Sway Bar
    Strobe Brake Light
    Aug 2007
    Greeneville, TN
    I've always wanted to install a nice RPG system with a dash mounted igniter. You know. For clearing out those pesky slow drivers blocking the roadway...
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    I thought it was only in Florida that they drive slowly in the left lane. Do like the idea of the RPG though.
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    I put a volt meter on the right and used Bob White's idea for mounting a Ram X-Grip, for my phone, on the left.
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
    Nov 2017
    Ok giving this a pre xmas bump for additional help. I've decided that I want to put a USB/volt meter combo where the analog fuel gauge is and a clock where the temp gauge is. For those that have done it, any suggestions or how did you do it? I can find 1 inch USB/Volt combos that are meant for cigarette lighters which would mean I need to by a hole cover for the 2 inch hole where the gauge went then bore it out and put the 1 inch USB/volt combo in it?
    I am learning late in life what many of you grew up learning to do so any help or product suggestions are appreciated.
    Baja Ron Sway Bar
    Strobe Brake Light
    I painted Deanna777's dash surround and that's what you will also need to remove …. 4 screws to detach it ….. However BRP gives the least amount of extra wire they can ….. so if you angle needle nose ( they work best here ) or any needle nose pliers, removing the connections will be much easier ….. then add the gauges of your choice , on my 14 RT I made my own spacer surrounds to fit the 12v plugs I added …… good luck …. Mike
    Apr 2019
    Florida Swamp
    Nitrous Oxide boost button?
    NOS
    2019 F3-S , Black & Silver
