Results 1 to 24 of 24
Thread: Laser alignment
    Very Active Member ahh-cool's Avatar
    Jun 2014
    south florida
    Default Laser alignment
    Who does Laser alignment in Texas?
    I'm in El Paso right now, will be leaving in a few days
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Aug 2019
    California
    I would suggest a phone call before adventuring out. 2 of the places listed in CA have been out of business a good number of years.
    Jun 2014
    south florida
    thanks
    Jul 2010
    Las Vegas, NV
    We will be in Deland Fl at Halloween. Come see us. Joe
    Joe Meyer
    Jun 2014
    south florida
    Quote Originally Posted by cptjam View Post
    I won't be back to florida till christmas
    SoFlo
    Maybe try Thoropolis, he posts often here and on FB.
    Jun 2010
    Las Vegas
    Quote Originally Posted by ahh-cool View Post
    We will be in Kerrville for Spyders in the Hills in mid October. It is a great rally, take a ride down and we will get you Squared Away
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member h0gr1der's Avatar
    Apr 2019
    USA
    I would definitely ask pertinent questions if using a dealership for alignment. Most dealerships are stuck on the original service adjustments, such as belt tensions that are too high and result in vibration. If you use a dealership, ask them specifically what toe in they use, even if they use the ROLO system to align the bike. Spyders often come with not enough toe in, which causes them to wander or dart. OEM Spec is 0° ±0.2°. All the highly recommended alignment guys add more toe in to stabilize the bike. Make sure that is what you're getting. Of course if you use someone like Spyderpops, Joe at Squared Away, or Lamonster you don't have to worry about such as that.
    h0gr1der
    2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
    States Visited on Less than 4 wheels.
    Sep 2013
    Houston
    We do laser alignments at our shop in Houston. Its a bit far from El Paso though. The rally in Kerrville would be much closer to you and Anne can get you squared away.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member RTSJohn's Avatar
    Feb 2019
    Killeen, Texas
    Quote Originally Posted by SpyderAnn01 View Post
    I'm hoping to install new tires before arriving in Kerrville in Oct. I sure hope I can get on your schedule for alignment while at the Rally.
    2014 , yes Pearl White
    Jun 2014
    south florida
    Where in Houston?
    Jun 2014
    south florida
    Where can I get info on the event?
    How far from Austin?
    Sep 2013
    Houston
    Active Member bayoubill's Avatar
    Aug 2019
    knox tn
    what should a laser alignment cost? the only indy dealer i can find near here [knoxville tn area] wants 170.00, seems a tad steep to me.
    2015 rs
    Jun 2014
    south florida
    We are signed up for Spyder in the Hills.
    Will there be any dealers there?
    I need a headlight under warranty.
    Jul 2010
    Las Vegas, NV
    Ahhhh, why not upgrade to a LED headlight? The stock light is dim and yellow. We will be in Texas - take a look. Joe
    Joe Meyer
    Sep 2013
    Houston
    Headlamp bulbs are not normally warranty items anyway. If you are going to pay for the labor to replace one, really should upgrade to LED and do both.
    Oct 2016
    Sebring, FL
    Airborne, what's going on in Deland, something special with Spyders?
    Jul 2010
    Las Vegas, NV
    Road Warriors event, Trike’s and Spyder event. 31 October to 2 November, Deland, Fl. I’ll find a website. Joe
    Joe Meyer
    Nov 2018
    Waynesboro, PA
    http://www.usspyderryders.com/incent...ovember-2-2019
    My Spyder
    2012 RTL , Brown
    Jul 2010
    Las Vegas, NV
    https://fallspyderfesttobenefitroadw...oundation.com/
    Joe Meyer
    Oct 2016
    Sebring, FL
    I did not know, and now I do. Thanks much team, I'm a couple hours from there, an opportunity to go see Spyders.
    Bill
    Jun 2014
    south florida
    Everything is under warranty for the first 2 years. I already had a bulb replaced under warranty, now the other one is out.
    I will check out the LED bulbs while I'm there
