Results 1 to 17 of 17
    Member P3EWO's Avatar
    Jul 2019
    Virginia
    Default Bike will not start
    Took the bike out tonight and rode fine. Was at lake for about 1.5 hrs. Tried to start and engine seemed to want to turn over but all the engine console lights came on and CHECK DPS popped up. Screen went blank then restarted from safety message.
    Tried letting it sit and trying again.. No joy. Same issue. The check dps only showed the 1st time. Other times only the entire engine fault lights on bottom came on... Screen went black, start over.
    Saw something about moving key away for awhile then trying again... No joy.
    150$ later it is towed home.
    2018 F3 limited with 700 miles...
    My 1st can am... Was in love with it... Now I am no so sure.
    Pick of what happens as soon as I push start. Screen goes blank and all lights on bottom light up.
    1980 Honda - CM400
    1983 Yamaha - Maxim 750
    1988 Kawasaki - EX500 Ninja
    1994 Yamaha - FZR 600
    1998 Honda - VFR800 Interceptor
    2008 Buell - XB12
    2018 Bitten by the Spyder Bug
    2018 Can Am - F3 Limited
    2018 F3 Limited , White
    Nov 2012
    North Las Vegas, NV
    Sounds like loose battery connections or bad battery.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2019
    Virginia
    Thanks for the response. I will look into the battery tomorrow. Thanks!!
    1980 Honda - CM400
    2008 Buell - XB12
    Jan 2019
    Toowoomba Qld Australia
    Do they not include roadside assistance while under warranty in the US? Maybe a call to BRP Care might yield reimbursement of the towing costs? Just a thought.
    2014 ST-S , Cognac
    Default Interesting....🤔
    From year and mileage I would agree it is in the battery connections or battery was not serviced correctly. Simple test would be a jump start with say a known good battery or the car with the engine off. The DPS is the biggest consumer of electrical power and not strange it would show up from lack of it. Let us know what you find...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Dec 2009
    West Oz
    To be precise, the starter motor is the biggest consumer of electrical power, DPS second. A battery related cause as suggested.
    Jul 2019
    Virginia
    Update: I put the bike on a battery charger for approx 3-4 hrs and the bike started up just fine.
    No lose cables.
    Not sure what would cause the battery to die, and will this happen again...
    Also, I called the dealer and they said it was under warrenty, but they would not pay for it to ne towed to dealer. I called BRP and they said roadside asst would cover the cost to tow to the dealer. Not sure why the dealer would not know this.
    1980 Honda - CM400
    2008 Buell - XB12
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by P3EWO View Post
    Update: Also, I called the dealer and they said it was under warrenty, but they would not pay for it to ne towed to dealer. I called BRP and they said roadside asst would cover the cost to tow to the dealer. Not sure why the dealer would not know this.
    I wouldn't be surprised if they did know it but where hoping you'd just eat the tow bill without question. It's easy to claim ignorance.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Jul 2019
    Virginia
    Another update. Took bike to dealer, they looked it over and said nothing is wrong with battery or anything. I told them it didnt make sense a bike with 700 miles would have a dead battery so soon.
    He said I need to keep it on a tender when not using. I ride it twice a week. I have had 6 previous bikes, much older, and never had to maintain battery on tender (except for winter storage).
    Question: is this normal for a spyder? Having to keep battery on a tender?
    Thanks for all the replies.
    1980 Honda - CM400
    2008 Buell - XB12
    May 2017
    Mesa, Arid-Zone-A
    The battery was probably installed by the dealer when new with no thought of making sure it was fully charged. If you are riding just short trips.....a few miles at a time, you may not be riding enough to replace the needed charge from starting. So, instead of the battery being fully charged, it gets weaker and weaker every time you start the bike. Then you end up having a problem like you did. OTOH, if you usually ride an hour or two at a time, it could just be a bad battery. Even new, it happens..... Jim
    Semper Fi
    Answer; NO!
    Something is up. Your Spyder, as you suspect, should be just fine sitting for awhile and still start up right away. There are several possibilities. Poor dealer prep sending you out with a less than fully charged battery. Poor dealer prep not getting good, tight battery connections. Having something left on draining the battery. Poor or weak charging (which the dealer should have checked). Or, simply a bad battery, which can happen.
    Hopefully, you are out of the woods. If the battery were not fully charged and you rode short distances, low RPM, maybe on winding roads. The charging system would not have enough time to bring the battery up to full, the DPS would draw a lot as well as the relatively frequent starting. It might have produced the perfect storm for your 'No-Start' event.
    Jul 2019
    Virginia
    Thanks for the replies. I never realized how much the DPS draws. I do recall taking some hard corners recently.
    Thanks again
    1980 Honda - CM400
    2008 Buell - XB12
    Mar 2018
    Ontario ,way up north
    This is the reason i carry a small booster all the time .I move it to the sled ( no pull start) when winter rolls around.
    2018 RTL , dark blue
    Active Member ChicagoSpyder's Avatar
    Chicago
    You should not have to keep your battery on the Tender with your schedule, in fact if you ride your Spyder only once every other month you should be good to go without the Tender, my guess is that the battery was either never fully charged and the setup guy was cranking the tunes while setting up your machine and others. Many times when a battery gets crushed it will not fully recover, even if it's new.
    2018 F3 Limited , Black/Chrome
    Chicago
    Quote Originally Posted by stmike 1800 View Post
    This is the reason i carry a small booster all the time .I move it to the sled (no pull start) when winter rolls around.
    Another BuRP cheap move, nothing like being in the bush at -40 and having a dead battery and no pull string.
    Mar 2018
    Quote Originally Posted by ChicagoSpyder View Post
    If your rope start fails do you have an electric start as back up . I have heard of more rope start failures than E start .I guess it would be nice to have both.
    GOS member (Girls On Spyders) Spyder_Cowgirl's Avatar
    Bowie, Texas
    Have your dealer, or you do it yourself, pull a recall report on your VIN. I suggest this because delivery of my 2018 F3 Ltd was delayed a couple of days because of a known problem with limited number of machines that had bad alternators that had ruined the battery (not sure of all the details). Bottom line, I got a new battery and new alternator before the machine was delivered and I was allowed to take it home -- parts were overnighted by BRP, so there was very little delay.
    All the best ….. Ann
    __________________________________________________ _
    2016 RT Limited -- "Jubilee" (as in Cherries)
    Guardian Bell (gift from spyderowboy)
    ISCI Dual Flag Mount – Tall Poles
    Lamonster Bottle Holder and Spyder Cuff
    Spyderpops Missing Belt Guard
    Spyderpops Bumpskid
    Spyderpops Rear Run / Brake / Turn LEDs
    Spyderpops Mirror LEDs
    Custom Dynamics HMT Brake
    Spyderpops Keep Out The Trash (KOTT) Grills
    Don't Eat Mud / mudflap
    __________________________________________________ __
