Bajaron Swaybar
Hi, I would like to know if all the Spyder F3 Bajaron swaybar have the Bajaron name written on it and if we can differentiate them from those of BRP, thanks
The bar themselves do not, but the links do. He also makes them for Lamonster garage and Spyderpops so they may have those names on it. The BRP bar will have plastic end links and no name on it. The ron bar can be used with the OEM plastic end links, but most people also used his end links with his bar.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
SpyderLovers Sponsor
Actually, the bar does have a BajaRon decal in the center. But you have to remove the under-plating to see it. Some customers have put my links on with a stock sway bar, but very few. If it has my links then it is almost assured it also has my bar.
I measured the diameter of both sway bars. For the OEM version, it is 14mm; Baja Ron's is 16mm.
