Results 1 to 11 of 11
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Paint or Covers for calipers
    Has anyone ever painted the calipers or put caliper covers on em? If so, do you have pics?
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Durham,Maine
    I have painted them on cars year passed, thought that it look good!!!
    2012 RTL , Pearl
    Houston
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Default Calipers
    They aren't difficult to paint , just make sure you are using High Temp paint if you do it …….annnnnnnnnnnnnnnd they even make a High Temp " Cognac " match ……. VHT - SP 402 …... Mike
    Mar 2013
    Maumelle, AR
    I painted mine a couple of years ago. Still looks good.
    2020 RT Limited , Chalk
    Sep 2016
    Chillicothe, Oh.
    Hi temp paint should work. I'm not sure I would cover them as these puppies can get HOT I wouldn't do anything that impedes airflow. One reason rear pads often wear quicker is because the rear caliper doesn't get the cooling air that the front calipers do.
    2015 RT , Black
    Jun 2018
    HAYMARKET,VA
    That looks Awesome JC! Is that a decal or did you hand paint the Brembo? Also, did you remove em to paint em, or did you leave em on the byke and mask everything off?
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Copperman View Post
    Did you take em off or leave em on and mask everything?
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    I'm thinking a grabber blue, like from the Ford Mustangs.
    Baja Ron Sway Bar
    Key Cover from Ebay
    SoFlo
    I would prefer proper brake caliper paint myself, however years ago Can Am did offer in the accessory catalog some kind of caliper cover to add some color to the calipers.
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by FINFAN3DP View Post
    I left them on and masked everything. I used G2 USA Brake Caliper Paint System.
