Results 1 to 10 of 10
    Aug 2019
    Stoughton, WI
    Default 2019 F3-S headlight removal ??
    Hey F3/S owners, I am running into a PIA replacing my OEM incandescent H4's with some LED's I had from my Triumph. I watched the Slingmods video, and everything was going good until I tried removing the front nose piece. That damn thing doesn't want to come out !! I have all the panels/mirrors/service panel removed, along with the nose piece nut/bolt. I lifts up, but it sure won't the heck pop off!! What am I missing?? I'm stepping away till I here some info as I haven't snapped/cracked anything as of yet :0. Thanks
    Jun 2010
    Las Vegas
    We just did lights on an F3 on Thursday, I still have bruises and cuts on my arms as we struggled for a long time trying to do it without removing the nose. Of course I can’t remember exactly how that piece came off but I know it wasn’t moving and then I think I lifted it from the top and it came off. I will see if Joe remembers.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Nov 2012
    North Las Vegas, NV
    Does it come off like that piece on the F3T? Those have hooks on the sides that that piece snaps over.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Apr 2019
    Florida Swamp
    Start on page 555 in the shop manual.
    2019 F3-S , Black & Silver
    Aug 2019
    Stoughton, WI
    Damn ... Not as easy as this video shows https://www.youtube.com/watch?v=WonVnHhR13U Just got the Madstad installed last week. I'll save this install for a later day.
    Sep 2013
    Houston
    On the F3S and base model, you access the headlight bulbs from the top, after removing the instrument cluster and service panel under it. Bulbs are right there to change out. No need to remove the housings. Almost as easy as changing them on an ST. F3T and L you have to remove the housings from the front.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Aug 2019
    Stoughton, WI
    Sheeesh ... According to the manual, you have to do both the panels and instrument/service panel. I got it all buttoned up now. I'll have a peek and try again via the instrument/service panel on the next rainy day .
    Jun 2010
    Las Vegas
    The pain in the butt on the one we did was removing his windshield and aftermarket accessories. Once those were off, it was easy. It is nearly impossible to change them out without removing stuff, there isn’t enough room to maneuver your hand to fo it from the rear.
    Joe said the panel in question has a tab on the top so you slide it up a little and then straight off
    2010 RT- 622
    Aug 2019
    Stoughton, WI
    Ha ... Yup, and I just put the Madstad shield on last Thursday. That's OK, I'll disassemble sometime this week. How convenient that my H4 9003 LED's I kept from my 800 Tiger are the direct replacement. They'll be in before I head down to Arkansas on the 30th
    Aug 2019
    Stoughton, WI
    Done
