Results 1 to 14 of 14
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Tricled rear lights
    Yesterday's tail end Spyder Mods complete!!! 2} side bag reflectors swapped for reflector/LEDs. 2} rear side bag run/break/turn signals. 3rd & 4th} led brake lights and 1} brake light Modulator. Started at 10am and finished at 9pm with a break for dinner. Now today it's on to the front. Here is some video of how the lights came out.
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Sep 2014
    USA
    Video dont work.. 11 hours to install??
    Jun 2018
    HAYMARKET,VA
    Video is working for me. Yup, took a long time because of the wiring and getting the rear panel on, which still isnt on right. Gonna try again today.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Active Member osj3's Avatar
    Aug 2018
    Greensboro NC
    Video is showing is private so it will only work for you. I would Love to see the video what you did
    2018 F3 , Black on Black
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    Quote Originally Posted by FINFAN3DP View Post
    May not have the small tab on the upper middle portion of the rear panel in the slot. If not, panel will not seat properly. Just a thought.
    Jun 2018
    HAYMARKET,VA
    Baja Ron Sway Bar
    Key Cover from Ebay
    May 2017
    Mesa, Arid-Zone-A
    Both Videos worked for me. Nice job. Very visible..... Jim
    Semper Fi
    Oct 2016
    Faribault, MN
    Kudos to you, I was chicken and had them install at Spyderfest a few years back. Feel much safer with all the extra lighting Reggie and Cindy installed.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Almost blinding in video form...perfect for on-road ryding! Nice job
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    2016 ST-S , Steel Black Metallic
    Nov 2018
    Claremore, Ok.
    Nice job on both the lights and the video, but the music was distracting . I'm envious of the clean shop, can you come over and clean mine, please. After a project I'm usually tooooo tired to clean up and it's gotten pretty bad.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Cool that's the setup that came on mine from the PO, now I know where they came from. Looks great.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Take a look at triclled.com site. There are still more lights you can add for safety and not just pretty show lights.
    Jun 2018
    HAYMARKET,VA
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2015
    Calhoun, La
    Default Battery Info
    I bought a battery that was not up to running my 14 RT from Batteries+. Started looking for the Yuasa YTX24 HL-BS a member advised. The local Honda dealer said he could special order one for $196. The Shreveport Can Am dealer said all he knew was a part number but would not take the time to look to see what it was, (it's whatever BPR sends he said). That was $170 from them. I found it on Amazon (where else these days) for $92. Imagine which I chose. It arrives Friday.
