Results 1 to 9 of 9
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Secret to getting rear panel above the bumper back on?
    Does anyone know the secret to getting the rear panel above the bumper back on so that the trunk door opens correctly. I have put it back on and the door shuts, but when you pull the latch you have to bang on the door to get it open. Not sure what I did wrong.
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Sep 2014
    USA
    Just make sure its seated properly on the top and sides. I found that on the top on mine was not seated properly and caused the issue you described.
    Oct 2016
    Faribault, MN
    It is a tricky process, to avoid breaking the tabs on the lower front and get the center of the rear panel clipped in properly. You may have to just remove the panel, take note of all the clips and where they clip into, and re-install the panel.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jun 2018
    HAYMARKET,VA
    Just cant get the door to open correctly. Everything else seems right.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Danbury Connecticut
    Quote Originally Posted by FINFAN3DP View Post
    Yes, it can be difficult.
    Here's the trick that I used.
    Install the rear panel and just barely tighten the hold down screws. You should be able to move the plate, but it should stay in place once it's moved. Then carefully close the trunk. This will index it to the proper position. Open the trunk and then cinch down the screws so it's tight.
    This worked for for the few times I removed the plate.
    Keep us posted so we know how you make out.
    As always, my free advice comes with a double your money back guarantee.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Active Member LongIsland's Avatar
    Dec 2018
    Long Island
    I found that if I install the right side and hand tighten the 1st bolt, then install the left side (no bolts), then hand tighten the top bolts, the trunk closes properly. I then
    install and tighten all bolts and the little screws on the inside of the rear panel. It works for me each time.
    Jul 2010
    Las Vegas, NV
    On the top of the painted panel is a small tab in the center. If you don’t get it in the slot in the black plastic, you mangle it, and the center of the panel sits proud (or higher than it should). Remove rear panel, inspect that tab. If it is ok, install with that tab in the slot. Seen a lot of mangled ones......very common. Joe
    Joe Meyer
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Quote Originally Posted by cptjam View Post
    This is the most likely cause. Everything else seems to be pretty straight forward, but this tab is easy to mislocate.
    Jul 2019
    UK
    What Joe said!... Without the tab clicked in, the panel just won't settle accurately.
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
