Results 1 to 12 of 12
    Mar 2019
    Ohio
    Default 3000 mile service
    Just got the 3000 mile service done on our 2018 spyder rt for $235.00 at River Raisin Power Sports in Monroe Michigan where we purchased it new. We dropped it off and they had it done the next day. The shop in Maumee Ohio wanted almost $500.00 and couldn't get to it for 3 weeks. Big thumbs up to River Raisin for their quick service. Great shop to use if your in the area.
    Jul 2014
    Mint Hill, NC
    A very reasonable price. Mine 4 1/2 years ago was $255. Think ahead and inquire if they will mount, balance and install the automobile tire you provide when your rear Crapenda dies.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Good price.
    Active Member TheCajun1957's Avatar
    Jun 2016
    Kilgore Tx.
    Hmmmm I have 3500 miles, need to have the first service done!
    2018 White F3 Limited
    Mar 2019
    Ohio
    Yes, we kind of last track and had almost 4000 miles
    Jan 2019
    Blue Mounds Wi
    That seemed like a real low price. Mine was $422.00. But the service guy went over a 2 page list with me of everything they inspect and check. They asked me about belt vibration. I was going to adjust it myself as the belt had moved all the way to the shoulder of the rear pulley but wasn't rubbing or removing the paint. I only had a slight vibration from70-72 miles an hour. So they measured the tension and adjusted the belt to have pulley clearance and put the same tension back on. I have zero vibration, it's really nice. They also did a DPS software update. I think my dealer is pricey but I am getting comfortable and trusting of them. They told me they would mount what ever tires I brought in.
    Aug 2008
    Genoa City, WI
    What dealer are you using?
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    Bought my 17 RTL there in February of 2018. A great bunch of people.
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    Hi JeffandLori,
    Is Engelhart your dealer?
    Quote Originally Posted by JeffandLori View Post
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
    Mar 2019
    Ohio
    River Raisin in Monroe Michigan was the dealer we used
    Sep 2019
    Port Perry, ON Canada
    Exactly what is done for your 3000 mile service other than oil change? I recently bought a new to me 2016 F3 which only has approx 1000 miles, so I still have a bit to go, but was curious.
    Very Active Member h0gr1der's Avatar
    Apr 2019
    USA
    Quote Originally Posted by Nrogers View Post
    Oil change and tighten the belt until it vibrates the whole bike.
    Actually, if your dealer is ethical, there's a bunch of stuff they're supposed to check. From my 2018 RTL manual. Your maintenance should be similar.
    h0gr1der
    2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
    States Visited on Less than 4 wheels.
