Results 1 to 8 of 8
    Jul 2019
    Pittsburgh PA
    Default Max mount extender?
    Have been seeing a lot of Rykers with an extender on their Max mounts, I want one but can't seem to find it anywhere. Can some one help?
    Sep 2019
    illinois
    I think what you are looking for is the "rear frame". Here's a link to an oem parts sight. The part I think you are wanting is part ID 800 da. I hope I'm not sending you down the wrong direction....good luck!
    https://www.cheapcycleparts.com/oemp...er-body-module
    Dec 2018
    NY
    Part 800 da is actually the rubber/plastic inner fender that fits inside the max mount to keep water off the riders on the RALLY model. It mounts to the max mount and is one piece.
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Jan 2009
    austria
    thats selvemade for a GIVI Topcase behind the passenger ..
    Member HERO's Avatar
    Sep 2018
    New York
    The part you’re speaking of is called the “upper rear fender”—price: $76.99. Part number 705013197.
    You’ll need the bolts as well—4 in total—Part number 250000995–price: $3.49 each.
    A fellow member of the site was the person who found this info—FBRKR. All the thanks should go to that person. I ordered mine from “Fox Powersports”. They order on a daily basis from BRP—so it took a week to arrive. Install was easy—had to remove the mount in order to place it properly. Best of luck to you!
    Jul 2019
    Pittsburgh PA
    Want to thank everyone was driving me crazy
    May 2009
    Connecticut
    From the Home Page you can click BRP Parts and follow till you have the Ryker fische with parts and prices and availability.
    Sea Doo GTI-SE 90 Jet Ski!!
    Mar 2019
    Lakeway, TX
    I bought this kit from RacingPowerSports.com, $100 shipped including the bolts.
    Last edited by Peter Aawen; 06-01-2022 at 03:38 AM. Reason: This user IS RacingPowerSports! :-/
