Results 1 to 18 of 18
    Aug 2019
    Minnesota
    Default What’s that smell?
    After each ride (it has been cool out lately) I back the F3 into the garage and notice a smell. At first I thought it was a hot brake but now it is more like hot rubber.
    Today after I got home I touched the belt and rear sprocket. They were room temperature.
    I don’t ride the brake.
    Does this sound (smell) like a problem?
    Thank you,
    ba
    2019 F3-T Liquid Titanium
    “we are all products of those to whom we have chosen to listen”
    2019 F3T , titanium
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    It is most likely a collection of cr@p sitting on top of the cat and burning.... One of the reasons I removed mine....
    Chuck
    Sep 2017
    Durham,Maine
    How may burn outs did you do!!
    2012 RTL , Pearl
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    It looks like your bike is fairly new. It may take awhile for all of the oils and other manufacting chemicals to burn off. After riding, put the Spyder in a dark area and shine a bright flashlight all around it. This should let you see if there is any smoke that you can track down.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Very Active Member h0gr1der's Avatar
    Apr 2019
    USA
    Quote Originally Posted by arachnyd View Post
    Thank you,
    ba
    I removed my belt vibration dampener for just this reason. It wasn't damaging the belt or dampener roller, nor was there ever any heat displayed on the pulley or belt. But I always smelled rubber burning. Removed the dampener and the smell went away. I'll live with the vibration as it was greatly reduced by lowering the belt tension to the lowest specification.
    Are you running a belt vibration dampener?
    h0gr1der
    2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
    States Visited on Less than 4 wheels.
    Feb 2019
    Portland, Oregon
    I was getting that burning smell too, but figured it was the "new" getting roasted. Got 700+ miles now and the smell isn't there now.
    Sep 2014
    USA
    Mine did that from day one on my 14 RT.. Once I got rid of the CAT I dont smell burnt rubber anymore. But never posed a problem even when it did smell like I did a BURNOUT.
    I sure miss those days when I could do burnouts
    Aug 2019
    Minnesota
    i have 500 miles so far. no vibration damper (yet). no smoky burnouts.
    i guess i'll just see how it goes.
    time to ride.
    thank you all for the help,
    ba
    2019 F3T , titanium
    Jan 2019
    SW Georgia
    Mine had that smell also, and it worried me. Now that I’ve done the cat delete the smell disappeared.
    May 2019
    Port St. Lucie, Florida
    Weird. I've been getting that smell, also. I figured that it might be the belt. I was looking to see what people were saying about belt tensioners, when I came across your post. Definitely a burning rubber smell. It's mild, but I've been concerned. Don't really want to mess with the stock exhaust system.
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
    Apr 2019
    Florida Swamp
    The back tire can throw stuff from the road on top of the cat. It will cook there. Any damp mud or if you run through some road kill it will smell until it is washed off or burns off.
    2019 F3-S , Black & Silver
    Northern Kalifornia
    Same roadster, same year, same smell, same modification, same results.
    Nov 2018
    Northern NV
    My F3T has the same hot rubber odor when I pull it into the garage. It didn't change one way or another when I added the factory belt tensioner. No signs of sprocket misalignment or unusual wear to date, either. Didn't think about road junk on the cat, but the smell is pure hot rubber. Guess I'll keep an eye on the belt when the riding season reopens.
    2017 F3T , Black, black and more black
    SoFlo
    Belt misalignment or excessive belt tension is a source of the rubber smell.
    When new, our RTS had the rubber smell. Correctly aligned the belt and the smell was gone.
    Just a suggestion. Possibly the others are correct and it is debris on the exhaust.
    Active Member Snakeyes's Avatar
    Nov 2019
    SE Pennsylvania
    I have noticed the same smell. I had "assumed" it was part of the break in period - tires, brakes etc. I now have 600 miles on the RTL and the smell has become less obvious each ride. I have done visual checks and everything seems to be in good order.
    2019 RTL Asphalt Gray
    2019 RT Limited , Asphalt Grey
    Greenville Tx
    When mine was new I had the same smell. It was the sticker on the Cat they did not remove on assembly burning up. It will go away after awhile.
    2017 F3 Limited
    Aug 2019
    Minnesota
    thanks for all the replies.
    ill keep and eye (nose) out for it once the riding season starts up again.
    2019 F3T , titanium
    May 2017
    Douglas Wyoming
    Default thank you for posting
    my F3 Limited has been doing this all summer
    2016 F3 Limited , Crimson RED
