Results 1 to 6 of 6
    Dec 2018
    Czech Republic
    Default 2020 Ryker models with increased power
    I have noticed 2020 models have increased power and torque. For 900 it is 5HP and 3Nm more than 2019 models. Do you think it is only optimized software and there is a possibility dealers can update 2019 models?
    Dec 2013
    I reckon it's almost certainly only the ECM, but I don't like your chances of getting a dealer to update 2019 models.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jan 2009
    austria
    thats the European Version !! - but it has less power till 0-50 miles/hour..
    Nov 2018
    N.E. Ohio
    Quote Originally Posted by Fixxxer View Post
    The 2019 models when they first came out was advertised as 77 hp. In the USA it was rated at 82 hp. shortly after being released here. cueman
    Monster Fuel …. has done AMAZING things with the 998, & 1330 Rotax engines …… I'm quite sure the same will happen with the Ryker engines ….possibly next year ….. jmho …. Mike
    Jun 2019
    Florida
    Correct me if I am mistaken, but the 900 already has more horsepower than the Harley 1450. I may be getting old but 105mph is fast enough to satisfy me. Thank goodness the rear tire can be replaced cheaply with a car tire. Hope to find a cheaper replacement for the front tires by the time I need to replace them. I wonder how the Rally would run if I replaced the front tires with something thinner. Bet it would turn better at lower speeds.
