Results 1 to 13 of 13
Thread: Oil leak
Hybrid View
    Active Member jcaburto's Avatar
    Jan 2017
    Whittier, Ca
    Default Oil leak
    My 2013 RT has developed an oil leak on the right side of the engine.
    Went down there to check and it seems to be coming off of what it looks to me like the water pump.
    Can you tell by these pictures if I'm right?
    I'm taking it to the shop tomorrow but I'd like to be prepared so any advise will be greatly appreciated
    Julio Aburto
    Black Currant 2013 Can-Am Spyder RT Limited
    2013 RTL , Black Currant
    Aug 2012
    Central Coast, CA
    Sure looks possible.
    2020 RTL SE6
    Jul 2011
    Mitchell, Ontario, Canada
    It does look like it. If it is the water pump oil seal. It will be coming out the leak indicator hole mark as 1 in the picture you attached. I would clean it. Then go for a drive and see where it is coming from for sure. If it is the water pump seal. You can't just replace the seal. The drive shaft and both seals need to be replaced as a set.
    Default Oil leaks.....
    Oil leaks are hard to pin point once it has run out and gotten wind blown around the engine. Back in the day we would clean the engine or area in question and spray it with Arid extra dry that dries into a white powder. Start the engine and wait for the trail ....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jan 2017
    Whittier, Ca
    After a nice clean up I was able to figure out the leak is from the clutch.
    The bottom part of the large rubber gasket is where the drops are coming from.
    Can this be replaced alone?
    I found the part number (420651242) (see #3 on the diagram) but I'm wondering if there's anything else that needs to be done once I open it.
    Thank you all!
    Julio Aburto
    Aug 2012
    Central Coast, CA
    Stupid question, maybe. But, did you check the bolts to see if they're snug? It's a total long shot since when leaks begin the gasket is usually compromised, but being a rubber o-ring style gasket you could get lucky and snug it down and stop the leak. Otherwise it looks to be a straight forward job.
    2020 RTL SE6
    Jan 2017
    Whittier, Ca
    Not a stupid question really... I did not check for that.
    I’ll make sure to do it today.
    Thank you!
    Julio Aburto
    Jan 2017
    Whittier, Ca
    So, since I had already purchased the gasket I decided to go a head and replace it. That seems to have stopped the leak.
    It did take a few hours but mostly because I did not have the right hex key to remove those 8 bolts.
    The only problem now is that my Harbor Freight lift broke when I was bringing the bike down. They changed their warranty to 90 days only so apparently is now ready for the scrap.
    Luckily the bike was almost on the ground and I only used it to put the bike up on the ramps.
    Julio Aburto
    Feb 2012
    Spring City,Utah
    Good job on the repair. On the lift take it to a weld shop and have it welded and re enforced.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2016
    RI
    Glad you didn't get hurt...this stuff is inexcusable...looks as if the welds weakened the material around the weld and it gave way and tore....could have been quite costly.
    Jan 2017
    Whittier, Ca
    I’ve been meaning to do a follow up on this.
    The problem I think is the release valve on the jack. You can’t control the speed when lowering the load so if you let go off the pedal midway down the load will jerk up and down very badly adding a lot of stress to the frame.
    I have a jack from the company I used ti work for which brings the load very slowly. I remember we asked China to put a better valve in there because of this issue. I will swap it up this weekend and see how it works.
    Unfortunately I never saw the actual valve so I can’t tell if it’s just a smaller O-ring that was added to get this done.
    And yes it was very scary to see that thing broken off after bringing the bike down.
    By the way, HF did replace the unit, even after the warranty was expired and I added extra warranty this time jus to be on the safe side.
    Julio Aburto
    Mar 2015
    forrest above Reno, Nv
    I have one of those jacks and found that if you press the pressure relief pedal all the way ---- it lowers slowly. Counter intuitive. You newer jack may not have this feature though.
    Lew L
    2014 RTS , Circuit Yellow
    Jan 2017
    Whittier, Ca
    I’ll give that a try.
    Tks!
    Julio Aburto
