Results 1 to 8 of 8
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    Default Anyone do laser alignment in Alabama?
    The front end of my 2014 RT-S has started twitching again, as it did when I first bought it in 2014, and the front tires are starting to wear on the inside edge of the tread. I had a laser alignment soon after I bought the bike, but the third party (not a dealer) that performed the alignment is no longer in business.
    The Montgomery dealer finally got laser alignment capability in June. I took it there but they claim the alignment is OK and toe-in is on spec. My 5 years in the saddle tell me otherwise, as does research across Spyderlovers. A properly aligned front end should feel planted, and what tire wear occurs should be even across the tread. So I think the dealer's lack of familiarity with the equipment is showing.
    So I'm looking for someone in the region experienced with the equipment. Anyone have any ideas? (I called the shop in Birmingham and they said they don't do laser alignment.)
    Thanks!
    Quote Originally Posted by Fat Baxter View Post
    Thanks!
    Contact Harvey @ " Spyderpops " …. He is real close to Alabama ….. Mike
    Jul 2010
    Las Vegas, NV
    ISCI does them.
    Joe Meyer
    Sep 2014
    Central Alabama
    Quote Originally Posted by cptjam View Post
    ISCI does them.
    Nope, not anymore. Jeff did my first alignment shortly after I bought the bike. Later he replaced the rear tire, and later still the fronts. So he was the first guy I called, last Fall for a new rear tire and this Spring for an alignment. He no longer provides these services. In fact, he pointed me towards the local dealer. So that leaves me looking elsewhere.
    (BTW, we just traded e-mails, me using my real name.)
    USA
    I did that. Planned a trip up to Hot Springs Arkansas as an excuse. Got Spyderpops to install my Baja Ron sway bar, laser align the bike, and install the missing belt guard. One caution however. Don't bring too much money, his shop is full of those kind of things that in the heat of the moment you just can't leave behind. I was very pleased with his service, very nice folks to deal with.
    h0gr1der
    Jul 2010
    Las Vegas, NV
    Bring it to Florida for the road Warriors rally. I’ll fix it! Joe
    Joe Meyer
    Active Member NorthAlabamaSpyder's Avatar
    Jun 2017
    North Alabama
    The Sport Center in Cullman, AL is suppose to be able to do this.
    https://www.sportcentercullman.com
    (256) 734-7636
    2019 F3-T and some extra stuff
    Aug 2020
    Muscle Shoals, AL
    The Sport Center in Cullman is where I bought mine a week ago. I asked if they do alignments. They said no.
