Results 1 to 25 of 27
    Mar 2019
    GTA, Canada
    Default Spyder RSS - rear top case and bracket
    I know that there use to be options... but a lot of them are discontinued (or at least I am having the worst time finding something).
    Are there still options out there for a rear top case... preferable installed behind the rear seat backrest?
    Active Member Nokesy's Avatar
    Mar 2017
    Newmarket
    I put on a Besteem box on top of the rear plate, works great about $85 Canadian from Amazon
    Done all of Canada except NWT and parts of Australia, New Zealand and areas of Europe
    Mar 2019
    GTA, Canada
    Quote Originally Posted by Nokesy View Post
    I don't have a rear plate... the rear passenger back support that I have is one piece, fixed (called the Roadster).
    Bossier LoUiSiAna
    Quote Originally Posted by mrNewt View Post
    sports rack & backrest are on EBay, maybe not color you looking for but can get that fixed later. the case however only came in black & required the sportsrack/backrest to attempt working. Unless u good at diy & have a hitch IMG_5024.jpg
    https://rover.ebay.com/rover/0/0/0?m...2F202670516879
    Mar 2019
    GTA, Canada
    Unfortunately, the backrest that I have right now is not the one that was build to work with the sport rack.
    The hitch is a pretty cool idea... but I don't have one .
    I guess my idea was more along the lines of a sissy bar luggage rack and then eventually I can add a top case on it.
    Aug 2018
    Thousand Islands
    Look for the ST one which will fit your style backrest. I had one on my 2011 RSS
    Part # 219400476
    2015 Canam Spyder F3-S SE6
    Detachable Passenger backrest #219400703
    Gauge Spoiler #219400531
    Blue Ridge Windshield #219400746
    Hood stripes decal kit #219400711
    F3 Idler Pulley #219800431 / Lamonster roller upgrade
    Bajaron SwayBar
    Elka Stage 2 rear shock
    Arc LED fog lights
    Lamonster F3 bar clamp with Quad-lock phone mount
    Foam Hand Grip Covers
    Tufskinz Peel & Stick Tank Protector Pad (Glossy doomed carbon)
    Sep 2019
    South Dakota
    Just an FYI, I am getting ready to remove my rear plate and reinstall original plastic and I will be selling it.
    Mar 2019
    GTA, Canada
    Quote Originally Posted by donhy View Post
    Part # 219400476
    Oh... did not knew there was the option for a case with the fixed backrest, thank you!
    I will start searching and see what I can find out there .
    Can you fit a full face helmet in that thing? For the passenger.
    Quote Originally Posted by Sputter View Post
    If is the one that is mounting on the fix backrest, then I might be interested... if I can afford it .
    Otherwise, I really do not want to buy another backrest.
    Aug 2018
    Thousand Islands
    It is the one that mounts on fixed backrest and it's quick release, It's a pretty good one if you can afford it
    And yes it fits a full sized helmet and i've got a pretty big head.
    Bajaron SwayBar
    Arc LED fog lights
    Mar 2019
    GTA, Canada
    Thank you for confirming it fits a full face helmet - that is one of the main reasons I am planning to get a top case.
    I'e already sent an email to the dealer where I got the trike from (to see what kind of prices they might have and if they can get it - usually are good at giving me some discounts when they can ).
    The "affordable" part was a reply to Sputter... regarding the plate that he wants to sell .
    Sep 2019
    South Dakota
    Everything I have is affordable unless I am buying it! I’ll take a picture tonight and try to send it.
    Sep 2019
    South Dakota
    Hope this works?[ATTACH=CONFIG
    Mar 2019
    GTA, Canada
    Thanks for the picture, but unfortunately that will not work for my setup.
    Based on what donhy is saying, there is an actual case that connects directly to the backrest... yours is a plate that replaces the backrest.
    Thanks... and sorry!
    Sep 2019
    South Dakota
    Anytime sir!
    Mar 2017
    Newmarket
    That's what I used as I had that plate on my bike when I bought it. I used the Besteem mounting plate, drilled four holes through the plate with 1 inch spacers. That way you can mount it forward or backwards on the plate. The besteem box has a back rest on the top box and by unlocking the plate you can remove the whole top box and put in the rear seat rest only or take the box off and leave the plates in place. My box in the 90 so it takes a full face helmet as well.
    Works great
    Bossier LoUiSiAna
    few possibilities with the sports rack depending on how you wanna go one of best I’ve seen so far:
    https://www.spyderlovers.com/forums/...dollar-luggage Followed by
    IMG_7423.JPGIMG_7573.JPG. Bolted straight to lid, believe GIVI monokey cases come with the mounting plates you just have to figure where & how you want them.
    IMG_7424.JPG or can go with brp rear rack bag part#280000317IMG_6237.JPGthey also have a passenger seat bag #280000320 also found a pic of my full face XL modular helmet in topcaseIMG_7579.jpg some room in corners for a roll of socks maybe to keep from bouncing around. Sissy bar bags work great tooIMG_3033.jpggood brands options & sizes available, personally like securing mine with a bike lock to the passenger grab rails(peace of mind till I get to hotel& it comes in room with me)
    Active Member Nobodyjj's Avatar
    Sep 2018
    Caledonia,Ontario,Canada
    Have same on 13 ST-S. Made by Givi.
    Mar 2019
    GTA, Canada
    I talked with the parts guy from the dealer where I got the trike and he said that BRP still had very few cases that mounts with the Roadster backrest.
    The guy was very reluctant to let me order it when he found out I am having the RS-S version; because on the spec sheet that he had, it was clearly mentioning for ST only.
    Soooo... here is hoping that it will fit. I don't see why not since as far as I know tail of the RS-S and ST is the same (but maybe BRP had a reason to mention ST only!?). The front is the one that has some differences.
    Here's hoping... he said that he should receive it maybe towards the end of this week. I'll update more then...
    Expensive as hell though... but considering is coming with the mounting plate (I assume) and the case, maybe is not that bad (around $650CAD ).
    But I need it for the passenger helmet and additional space so... yeah, I bent over .
    Aug 2018
    Thousand Islands
    I talked with the parts from the dealer where I got the trike and he said that BRP still had very few cases that mounts on the Roadster backrest.
    Soooo... here is hoping that it will fit. I don't see why... since as far as I know tail of the RS-S and ST is the same. The front is the one that has some differences.
    Here's hoping... he said maybe towards the end of this week should receive. I'll update more then...
    Guaranteed it will fit and you will love it. The top case mounts on the backrest not the bike itself so it has nothing to do with RS vs ST not sure why the advertise it for ST only since the new style backrest is the same part # for both bikes.
    Bajaron SwayBar
    Arc LED fog lights
    Mar 2019
    GTA, Canada
    Thanks for giving me more confidence !
    I believe you... that's why I pressed on and insisted on ordering - promised I will buy it no matter what, so now I am invested .
    It is very odd that I cannot find any kind of pictures with the seat installed. I mean more detailed pictures. I am curious how it actually mounts on the seat.
    Mar 2019
    GTA, Canada
    Got, installed it and love it.
    Looks better than I was expecting - kind of completes the look of the trike.
    Thanks all!
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    Does the Givi topcase lid open when mounted just behind the backrest?
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Aug 2018
    Thousand Islands
    You owe me a beer
    Bajaron SwayBar
    Arc LED fog lights
    Mar 2019
    GTA, Canada
    Quote Originally Posted by oldgoat View Post
    It does, but with a quirk.
    Under the mounting plate, there is a lever that you pull and allows for the plate to tilt 45 degrees. And then the top case fully opens.
    I thought it might be annoying, but after using it a couple of times today (went for a 9 hour ride), I did not find it annoying at all. Kind of like it...
    You owe me a beer
    I sure do - If we ever cross the roads, you have a beer guaranteed .
    I see you are in the 1000 islands area - I'm Richmond Hill.
    Jan 2019
    Boulder City Nevada
    Did you remove the rack yet and is it for sale
