Results 1 to 5 of 5
    May 2019
    Ellettsville, Indiana
    Default Cant open front trunk
    Can't open front trunk on my 2009 RS. What would cause this?
    Quote Originally Posted by GPDL98 View Post
    over-filled frunk, or the cable could have come off the base of the ignition switch ….. the second one is almost as easy to fix as the first …… Mike
    Bossier LoUiSiAna
    Try pushing down on top center (where latch post is)of frunk lid as you turn key hopefully simply overfilled or something hanging over the seal lip, causing the lid to sit lil tighter than normal
    Jun 2019
    Scottsdale, Tasmania
    Or a broken cable, this happened to me
    2014 RSS , 4 eyes conversion for headlights, 12v socket, 2x USB Ports, CTEK Charging Port. Black and White
    Active Member Web Runner's Avatar
    May 2013
    Houston, TX
    Hello, I had this happen to me as well. The problem turned out to be the cable itself. It had stretched enough so that it would not disengage the latch. I had to manually push the latch under the frunk lid with a flexible plastic rod.
    2010 Full Moon Silver RS SE5
