Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
  1. #26
    Nov 2013
    Oro Valley Arizona
    Mine was sealed from the factory as was the replacement. No acid has to be added nor can it be added to a truly sealed battery. There is no way to add anything because it is sealed tight at the factory. There are many copies out there that are worthless. if you try to cheap it out you may not be getting the real McCoy. I believe I paid about $120 for my replacement and it is great. I never use the Battery Tender but try to run it at least once every two weeks.
    OEM lasted five years even in this Southern AZ heat. Normal battery life here is 2=3 years.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
  2. #27
    Dec 2015
    Oakley Utah
    The battery with acid supplied separately is AGM. You seal it tight after adding the acid so it becomes a sealed AGM.
    I don't think so but I'm keeping an open mind.
    2014 RTL Platinum
  3. #28
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    Here is the battery that came from Amazon.com https://www.amazon.com/Yuasa-YUAM625...gateway&sr=8-3 Just received a call from the Interstate store said battery was charged and ready to go.
  4. #29
    Dec 2015
    Oakley Utah
    Quote Originally Posted by OlJim View Post
    That's interesting. In the description it says the battery is supplied dry with a separate acid bottle.
    My apologies to IdahoMtnSpyder. I learned something new (again)
    2014 RTL Platinum
  5. #30
    Dec 2015
    Oakley Utah
    The battery was charged per the instructions provided by the manufacturer before installation.
    Did the Interstate shop do something differently than what you had done to charge it initially? It's supposed to be slow charged over 10 hours from what I understand.
    Whenever I've purchased a battery from BatteryStuff, it has come filled and charged. Maybe that's what accounts for the differences in price and outcomes between apparently identical Yuasa batteries?
    2014 RTL Platinum
  6. #31
    May 2015
    NE Oklahoma
    The Interstate guy said it was the new chargers that would not charge if the battery was below a certain level. All they did was hook up a set of jumper cables to a good battery and charge both at the same time. He also said the initial charge didn't make that much difference in battery life.
  7. #32
    Aug 2013
    SF Bay Area
    Just a response from Yuasa that clears up the confusion.
    Thank you for your inquiry.
    I will be glad to explain the differences between the two.
    The YTX24HL is factory activated and the YTX24HL-BS comes with a bottle supply of acid and has to be activated by the dealer or user. If you take a look at the specs for both batteries, they are identical.
    YTX24HL:
    https://www.yuasabatteries.com/battery/ytx24hl/
    YTX24HL-BS:
    https://www.yuasabatteries.com/battery/ytx24hl-bs/
    If the battery lays at an angle inside your Spyder, we recommend going with a factory activated battery. If it sits upright, you can go with either one.
    2021 F3 Ltd , Magna Red
  8. #33
    Dec 2015
    Oakley Utah
    YTX24HL:
    YTX24HL-BS:
    Good to know. Thanks!
    2014 RTL Platinum
