Results 1 to 7 of 7
    Active Member amusher's Avatar
    Apr 2015
    11 Mile/Spinney CO
    Default Broken front fender bracket
    2015 RTS - Has anyone had trouble with the front fender brackets breaking at the joint where the two sizes of tubing come together?
    Quote Originally Posted by amusher View Post
    I did on my 08 GS, ….. My shocks when bad and that extra vibration caused one to break ….. two other Spyders later with no issues ….. your cause may be different … good luck …. Mike
    Default Others...
    There have been others during my time here. More with the rear fender on the GS/RS/RSS but BRP later updated them. May have been a poor weld but most likely considered a wear and tear item so you may just re-weld or replace it...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Apr 2015
    11 Mile/Spinney CO
    This is on a friend's bike. First one side that was replaced, then a couple of weeks later the other side... Just curious if this was something common. Thanks for the replies.
    Jul 2011
    Mitchell, Ontario, Canada
    Yes it happens. Same place you describe. But not that common. Mostly it comes down to a bad tire or something else the causes a vibration.
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Your friend don't need no stinkin' fenders.
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    I have on my 2013 RT, I threaded both pieces for 3/8" stud to be screwed together and then welded and painted.
    2014 RT SE6
