Results 1 to 13 of 13
Thread: Battery Drain
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    Default Battery Drain
    When I return from a ride and put my 2017 RTL in the secure barn, for convenience, I always leave the key in the ignition.
    Does this cause a small drain on the battery due to the key chip communicating with the D.E.S.S ?
    Its not really an issue because I always hook up a battery tender. Just curious. Thanks
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
    Default Not sure...
    Don't know that it does or has cut off but I always remove the key and keep it in a set place on the way to the ryde. I find the computers run their shut down and reset faster and the throttle body as well. I know many around here that do not use battery tenders and leave the key and have never had any drain to the battery. If you use a battery tender you need not worry for sure.....
    ​2012 RS sm5
    SoFlo
    No. The key is turned on, that energizes the DESS in simplest terms. Key off, no DESS.
    Did not seem to be a problem here. The Spyders were in the hands of the movers for 70 days. The keys remained in the ignitions. They started first try upon arrival here.
    Oct 2017
    Thanks for the reply's
    Gary
    1987 BMW K75s
    Jul 2014
    Mint Hill, NC
    For me the set place for the key on the way to the ryde is in the ignition.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Idaho
    Quote Originally Posted by Garf View Post
    No, but there are several inputs to the cluster and vehicle control module that receive power directly from the battery at all times. How much current constantly moves through those two units I have no idea, but there is some. They have volatile memory in them meaning they need power constantly to keep the memory active. Lose power, lose memory. Any Spyder will eventually run a battery down. The older and weaker the battery the quicker that happens. My 2014 RT with the original battery went completely dead a couple of days ago after sitting and not being ridden and not connected to a tender for 10 days.
    2014 Copper RTS
    Sep 2017
    INDIANA, USA
    Default Key
    Remove the key and put it on kitchen table. I have a small container on my table that I use....
    ENJOY YOUR LIFE WITH A SPYDER
    Bossier LoUiSiAna
    Know there was a report someone forgot the key in garage was not well insulated everything got cold, failed to start following morning till key was indoors & warmed up a bit.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jun 2010
    Las Vegas
    I never take my key out, it is hot as Hell in our garage and I’ve not had any issues.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member ChicagoSpyder's Avatar
    Apr 2019
    Chicago
    I'll have to try that this winter, although it doesn't make sense seeing Bombi has been using DESS in sleds for many years before the Spyders came to market.
    2018 F3 Limited , Black/Chrome
    Jul 2011
    Mitchell, Ontario, Canada
    On a later models with a 1330 engine like yours. All modules will turn themselves off in less than 3 minutes and draw no power. There is one exception and that is the gauge cluster. Just enough power to keep the clock running. Maximum parasitic draw should be less than 20ma.
    The models with 998 engine and fly by wire throttle. The ECM stays active for 40 minutes.
    2018 F3 LIMITED
    Jul 2011
    Well that makes no sense at all. Sounds like someone made that up or there happened to be a coincidence of some kind.
    2018 F3 LIMITED
