Results 1 to 6 of 6
Hybrid View
    Jun 2018
    Sioux Falls SD
    Default Genius Map odd directions
    I have now used genius maps for several months. The app gets me where I am going but gives me some odd directions. Many times it tries to have me go through residential areas instead of staying on the main through fare like google maps does. It also guides me to gravel roads even though I have it set up to avoid them. If I say avoid highways I really get sent through a lot of residential areas.
    I have ran both genius maps and google at the same time and get different directions, google always keeps you on the main roads until you are very close to your destination.
    Am I missing something or is it just the nature of the beast.
    Jul 2011
    Mitchell, Ontario, Canada
    It will be in your settings. Look at avoidances choices.
    Rarely will 2 gps units or apps will route the same. That is because there will be likely differences between the 2 of them. Different maps, route setting, etc.
    Active Member KenInMN's Avatar
    Dec 2018
    Albert Lea, MN
    I've noticed the exact same things. It is constantly telling me to turn onto gravel roads. It has also had me get off of a main route onto surface streets only to have me back onto the main route a few miles late. Not the best Map system out there....
    BKMNI
    RWP!
    2018 F3 Limited
    Intense Red Pearl
    2015 Harley Davidson
    FLRT "Freewheeler"
    Vivid Black
    2018 F3 Limited Dark , Stock Intense Red Pearl
    We ran into the same stuff on our trip from AK to AR. I was misdirected the "long" way at least two times. I take GPS info now with a large grain of salt.
    Aug 2013
    SF Bay Area
    Kinda why I use Sygic instead. The only thing I don't like is it constantly reminding me that a turn is coming up.
    2021 F3 Ltd , Magna Red
    Active Member Blake33's Avatar
    Mar 2013
    Lakes Region of NH
    I prefer Sygic too, although I can't understand why it wastes 1/3 of the already small display screen on the right side of the dash display. I would much prefer that it use the entire display area to show the road graphics. Or am I doing something wrong?
    That being said, neither Genius Map or Sygic are nearly as good as the good old Garmin Zumo 660 on my 2012 RT!
    2018 RT Ltd.
    2018 RT Ltd , Oxford Blue/Chrome
