Or, you could cut the remnants of the hook off, fit the panel into place to get the correct location, & then (carefully) drill thru the cover panel and the underlying panel & fit a D-ZUS clip instead! They postitively lock the panel on when it's in place, no chance of that panel ever coming off with the D-ZUS engaged, looks as tho it's meant to be there, and yet the panel can be taken off just as quickly & easily as ever!
