Results 1 to 7 of 7
    Jan 2019
    North Carolina
    Default FLH side panel hook broken?
    Hi folk, I assume the hook at the top right of the cover is broken?
    And if so it appears I can get a new one and glue it on? OP
    Feb 2019
    Portland, Oregon
    For repairing plastics, I found Plast-aid to be the best for sticking things back together. Easy to use.
    https://www.amazon.com/Plast-aid-801...51615582&psc=1
    Jan 2019
    North Carolina
    The next question would be, if it is indeed broken, where do I get a replacement?
    My dealers parts guy is new, he thinks I need a new panel!
    Sep 2018
    greensburg,pa
    Quote Originally Posted by Jackhartjr View Post
    https://www.cheapcycleparts.com/oemp...torcycle/parts
    2018 RT-L , Blue
    Or, you could cut the remnants of the hook off, fit the panel into place to get the correct location, & then (carefully) drill thru the cover panel and the underlying panel & fit a D-ZUS clip instead! They postitively lock the panel on when it's in place, no chance of that panel ever coming off with the D-ZUS engaged, looks as tho it's meant to be there, and yet the panel can be taken off just as quickly & easily as ever!
    There's a pic in post #6 of this thread: https://www.spyderlovers.com/forums/...ighlight=D-zus
    Jul 2010
    Las Vegas, NV
    Love that, Peter!
    Alternatively, a 2” strip of Velcro, applied to the top surface, works great!
    Joe
    Joe Meyer
    Jan 2019
    North Carolina
    Thanks for the replies folks, as usual, y'all came through!
