2019 F3-T leaking rear airbag (or use)
Was wondering if BRP was warranting this? Should I just fix it myself? Will it hurt to use fix-o-flat type stuff? Thanks in advance
2019 F3-T and some extra stuff
Ozzie Ozzie Ozzie
What's it doing that makes you think the air-bag is leaking??
Been driving on any dirt roads or recently chip-sealed roads lately? Regardless, I'd still be trying the warranty approach first, only don't leave your Spyder with them!
2013 RT Ltd Pearl White
Ryde More, Worry Less!
It would probably hurt.
first I would make sure the bag is in fact leaking, If it is, and if it has any warranty left I would go that direction, if it don't then change it out with a new one! It may be a leak in one of the hose connections! I would not put fix a flat in that system you will regret it!!!!!
