ABS Error Codes 2016 F3T
Tried the reset steps but no go. Check brake fluid level and floats which are fine. No leaks evident.
Error codes are C1290 -C006C -C1200
Appreciate any code information and suggestions.
C1290 is voltage failure to the VCM.
Possible causes
VCM supply voltage is much too high or too low.
VCM supply voltage spike glitch.
Service actions
Measure battery voltage with engine stopped (expected value: 11 to 13 volts).
Measure battery voltage with engine running (expected value: 13 to 14.7 volts).
Check connections on voltage regulator.
Check ground and positive connections on battery.
C1200 VCM valve failure.
Possible causes.
Power supply or ground circuit failure to the VCM.
Internal valve relay defective.
Service actions
Check VCM valve fuse MFB78.
Measure voltage between harness connector VCM-25 and ground (expected value = 11 to 13 volts).
External troubleshooting is not possible, if internal valve relay defective, replace the VCM.
2018 F3 LIMITED
C006C VCM error or failure reported.
2018 F3 LIMITED
Checking the wiring diagram. The VCM valves are powered through fuse J2 in the left fuse box. That's where I would look first.
2018 F3 LIMITED
