I heard that the rykers are not "suitable for longer tours" - (a joke?) so I tested it by myselve before we start our 35th honeymoon trip to southern Italy ..(2up)
On my first Exit at the Dealer I was unhappy with the front, so they added the sway-bar and now it is a perjekt Power-sport-tourer (rear Fox /side case/Toyo tire) I added a bigger Windshield, a Topcase with a"flat" seat for my Girl and use an old Tank back ...
Despite faster driving, consumption is about like our old V2-RT – the range is about 190 miles to refuelling (fits in the tank more than in the catalogs??)
The performance is now better than on the Spyders and with the drive-shaft you can finally drive around a bit Off-road - the maximum Speed is enough for it, normally we ride 60-80 mls/hour .....
Pretty much the best BRP has ever put on three wheels!!
(after 1.600 miles the driver seat is not really for longer tours - so I hope to get a "comfort" one soon)
Nice review and detail on how to better make your ryker a bit more suitable for the long ryde and double up at that. This should help those on the fence about the ryder. Thanks for the information, test and results. Thank the passenger as well....
Vielen Dank, Köszönöm, Merci, and Thank-you!
Clear and concise personal experience is SO much better than all the conjecture.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020
My gauge reads low miles to empty also when full. But I figured out is that what you have to to is MATH. Reset your trip meter to 0 at fill up. Then enjoy riding not looking at the "Range" mileage. (I usually watch MPG consumption, around 37 mpg on ECO) Then when fuel gauge drops down one bar add "Range" mileage to your Trip Distance Mileage. It will be greatly improved and it will get better on down the road. Example trip distance at 87 miles, range at 105. that makes close to 192 miles to the tank full. To be on the save side assume about 5 miles short of that.
BTW this is my 1st reply ever. I hope i didn't confuse all of us!!
