Results 1 to 25 of 26
    Mar 2019
    Depoe Bay Oregon
    Default Saddle bags, a work in process
    I have wanted some saddle bags for some time, I use my Ryker daily and it would be nice to do a little shopping and have room for rain gear etc. https://www.ebay.com/itm/Leather-Mot...oAAOSwKg9dBnxq
    Bought these bags and made a temporary frame from abs pipe. I have tested it with about 12 ilbs on both sides at high speeds and there fine. I still am not sure what to do with the rear bracket, just sitting on a leather stripe to not make up the fender. I made a cable with lock to go through the bags so they don't disappear. When down the road I will either make a stronger frame or look at a max mount. I have just under 10,000 miles on my Ryker and still having a blast riding. Sorry about the pic being sideways, don't know how to change it on this web page.
    Jun 2019
    Florida
    How's this?
    Jun 2019
    Florida
    I am looking at doing the same thing. I want a luggage rack to haul stuff that won't fit in the saddlebags, but I also want the saddlebags. But, I want the luggage rack easily removable so that I can slide the passenger seat on if my spouse wishes to ride with me.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    I'm doing the same thing and will be working on a bent tubing frame for supporting the side bags from swinging in and hitting the rear tire on my Rally.
    I have experience bending tubing but I don't have one at home so I am right now looking into getting a 1/2" tubing bender. I will keep you updated on my progress.
    Mar 2019
    Depoe Bay Oregon
    Quote Originally Posted by MDLNB View Post
    How's this?
    Thanks!
    Jul 2010
    Las Vegas, NV
    Nice job! For running around town, rain gear, water bottle. Perfect. I had no idea leather saddlebags were so cheap! Good find!!
    Joe Meyer
    Default Love the DIY's
    Well done and when the testing is done you will have just what you need. With this leg work done you will help a lot of folks work out the same problem. This is what the site is about... Thank and let us know how the final set up works out....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jan 2018
    NH
    Here is what I have so far. They are made out of 3/8" dia 316 Stainless tubing and attach between the two 8mm bolts under the seat and the 8mm bolts on my passenger seat backrest. I bent the tubing and then flattened the ends out where the bolts go through to make a wider through hole area. I also added stainless washers behind the tubing because the original bolts were counter bored into the frame.
    I am still in the process of finishing them. I'm adding JB weld to permanently attach the washers to the tubing for extra stability and then everything will be painted black.
    IMG_20190921_110054 (2).jpg IMG_20190921_110103 (2).jpg IMG_20190921_110115 (2).jpg
    Mar 2013
    Quote Originally Posted by Markubis View Post
    Nicely done
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Mar 2019
    Depoe Bay Oregon
    Nice job, there are as many ways as there are ideas. I ended up making my from from 1/2 copper and painted black. I had to keep it lower than the seat so with my back and leg issues I could still get my leg over the seat. It sure is nice to have storage for clothes food or what ever I need at the time.Stainless would be better but where I live on the coast I'm lucky to have hardware stores.
    Jan 2018
    NH
    Quote Originally Posted by oregoncoast View Post
    Yeah, hardware stores around here don't carry stainless either. I got mine from McMaster Carr and went with the lighter weight .031 thick wall, knowing that tubing is already going to be very rigid so lighter weight walls were fine. Plus my tubing bender was able to handle thin walled stainless.
    Sep 2019
    San Luis Obispo, CA
    Amazing job on that tubing!
    Florida Swamp
    I have built several pieces to bolt on behind the passenger grab handles on the F3-S out of stainless steel. Currently working on saddlebag mounts when I have the time. I used small diameter solid stainless steel round stock. It can be easily heat bent without collapsing and is available on the internet.
    https://www.onlinemetals.com/?gclid=...SAAEgLQJfD_BwE
    They sell small amounts by the foot or custom cut, many different metals and sizes. Flat stock, round stock, tubing, sheet, whatever you need. Always got fast service dealing with them.
    2019 F3-S , Black & Silver
    Jun 2019
    Florida
    Nice job. Professional looking. How do you get the passenger seat off, or are you planning to leave it on permanently?
    Jan 2018
    NH
    I have no plans on removing the passenger seat. I like the look of the passenger seat and backrest over the rear wheel. If I did want to remove the seat, I would have to remove the 4 bolts holding on the saddlebags supports.
    Jan 2018
    NH
    i had a little set back on finishing these. I originally mounted them to the frame and had to buy longer 8mm bolts since they would no longer be sitting in counterbores. I decided to get stainless steel...figuring I was being smart since SS handles weathering better.
    Bad move...but found out something interesting.
    The bad thing was that one of the bolts ended up galling inside the threads on the frame of the Ryker. I managed to get it out after drilling off the head and then working it out slowly but surely using some channel locks.
    The good news is that the threads on the frame of the Ryker are stainless so that's a plus in my book.
    Mar 2019
    Depoe Bay Oregon
    Your not the only one with a issue. My first set of copper I had used both bolt holes on each side, forgetting the seat moves. I cracked a hole in the copper, I replaced it and just used the first hole and also put a wood dowel in the copper where the bolt goes through. So after a couple of weeks it seem ok, but I check the whole rack over before every ride. You will figure it out.
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    Stainless steels are prone to galling when similar alloys are used together. You may remember the galling issues when manufacturers of Model 1911s began producing stainless steel frames and slides back in the late 1970's. The answer then (and now) is to use Never Seize (or a similar product) during assembly. This is a copper based grease that will prevent the problem.
    2019 Ryler Rally , Shock Yellow
    Jul 2010
    Las Vegas, NV
    Thanks to you, I have a set of those bags! Nice, hold what we need, look cool, and thrifty! Thanks for the inspiration! Joe
    Joe Meyer
    Jan 2018
    NH
    Here is my finished product. I painted the stainless tubing flat black (though it looks more satin to me) and I have Sedici saddlebags that I got at Cycle Gear for $120. I have the saddlebags attached to the tubing with some two sided velcro strapping that I got at the hardware store.
    Nov 2018
    N.E. Ohio
    Thanks for taking the time to pass this on. cueman
    Central NJ
    Markubis
    i have the 900 with the full rear fender, but i don't have that extra extension behind the passenger seat that your photos shows.
    where did you get the extension or did you make it?
    great job on fabricating the tubing
    Oct 2019
    Georgia
    I brought the shad side saddlebag having a difficulty time with the 2longs screws. With the lock tie it does not screw in properly. I stripped it. Have to see if I could get 2 without the lock tie at the end of screws. Not happy about that.
    Oct 2019
    Georgia
    It’s obvious when my max mount and seat was installed it’s not aligned properly. There the screw does not work. Purchase 2 shorter screws from home depot that tends to work. It’s fits tightly and secure.
    Active Member Texas Al's Avatar
    Jun 2017
    Azle TX
    Greckman you can get the extension from part shark, they are the fender for a Rally bike. But you don't really need it, if you have the passenger seat.
    Here is my set up. I am waiting foe the hard bags like Ryker Rick has, they are currently out of stock.
    2021 900 Ace , Black & Gold
