Need LED Latching Switch Dia?
I’m planning to wire in one of Dave’s heated seat elements and I’m going to use a Led Latching Switch, similar to those that are used in the F3 Fog Light Kit (for the accessory holes on either side of the steering column). Can anyone tell me if the diameter of the switch/holes are 16mm or 19mm?
Thanks
Reason: Prefix & title
Perfect. Thanks Jiffy
Thanks
Like this? https://www.amazon.com/Latching-URTO...28156101&psc=1
Good idea . Thanks.
2014 RTL Platinum
Originally Posted by UtahPete
@UtahPete, that's correct. I will reach out to MotorCycle Dave to ask how many amps are his seat heaters. Those buttons are 5amps but it might not be a issue because I'm adding a relay in circuit.
