Results 1 to 23 of 23
Thread: F3 changes 2019
    Jun 2014
    Ellsworth, KS
    Default F3 changes 2019
    Looking at getting 2019 or waiting so see what comes out in 2020. Was looking at available after market accessories and noticed there are quite a few that will fit all but 2019. What changes have occurred since prior years? Tried the search feature, but no luck. Thanks
    Aug 2019
    Stoughton, WI
    I just picked up an F3-S this week. As far as the F3/S, I think the only changes were body color options, wheel color and new dash display. Sounds like 2020's could be quite different. Might be able to score a 2019 for a great price..
    May 2013
    Apex, N.C.
    In addition, the turn signals were removed from the mirrors and placed on the fenders. Those were the main changes between the 2019 and prior years.
    Aug 2019
    Stoughton, WI
    Yup, forgot that. I didn't like that change
    Active Member 2RTsGV's Avatar
    Sep 2014
    Grain Valley MO
    I heard someone discussing that the electrical system is not as accepting of aftermarket added lights. If this is so, I assume the 2020 models will be the same
    I love how the earth rotates around the sun ... it really makes my day!
    Currently Own:
    2019 F3 Limited - Vegas White (Dark Edition) - His
    (Baja Ron bar/links-Short reach bars-Center footpegs-Tall boy screen-Flag holders-LED Skidplate-Spydercuffs-Ultimate seat-LED Headlights)
    *** BLOWN MOTOR Apr 21 @3,800 miles, motor replaced by BRP Jun 5, 21 ***
    2019 RT Limited - Phoenix Orange (Chrome) - Hers
    (Baja Ron bar/links-Skidplate-Spydercuff-Comfort seat-LED Headlights)
    Previously Owned:
    2013 RT SE5 (Orbital Blue) *31,000 Miles* - His
    2012 RT Ltd SE5 (Pink Full Body Wrap) *41,000 Miles* - Hers
    2021 Ryker 900 (Black) Sport Windshield - Foam Grips - Solo Comfort Seat
    Florida Swamp
    Quote Originally Posted by 2RTsGV View Post
    That is wrong. The electrical system on the 2019 F3 is wired for many of the same accessories that are standard on the more expensive models. The wiring is already there and all you have to do is plug the compatible accessories in. There is also plenty of customer circuits already there to wire other items into.
    Don't believe everything you hear.
    2019 F3-S , Black & Silver
    Sep 2014
    Grain Valley MO
    Well thanks for clearing that up
    Currently Own:
    Previously Owned:
    Mar 2017
    2019 F3 all models come with a 79 (small) toothed rear sprocket. 28 up front like all the others. Earlier US models had an 89 tooth rear.
    This has been corrected. S has 89 teeth.
    Aug 2019
    Battle Creek, Michigan
    I thought the 2019 F3s still had the 89 tooth
    Florida Swamp
    Quote Originally Posted by Jengland View Post
    Parts list items.....
    Carbon Black - Pulley Ass'y, 79 Teeth Australia, Europe, Japan
    705502016
    Carbon Black Sprocket 89 Teeth Ass'y Canada/USA
    705502187
    Mar 2017
    Quote Originally Posted by Gwolf View Post
    705502016
    705502187
    xxx xxx xxx
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Quote Originally Posted by kll View Post
    On the RT & F3 touring models the front fenders are now a 1 piece moulded part
    Therefore the existing Front Fender LED Reflectors do not fit
    (Possible access issue)
    I suspect the suppliers are working on a remedy for this
    That’s why at present it states up to 2018 models
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Florida Swamp
    Quote Originally Posted by Rattlebars View Post
    Parts list does not show the "S" having 89 tooth. Only 79 is listed ->https://www.partshark.com/oemparts/a...ve-system-rearisted.
    The parts list you linked looks exactly like the one I use. I see both pulleys listed on it. They can call it a pulley or they can call it a sprocket, it is the same part. The part number is the same. Only the region and what they are calling it is different, with different number of teeth.
    Mar 2017
    xxx xxx xxx
    Florida Swamp
    All the other years and other 2019 models have two pulleys in the fiche picture. I defer to your expertise. Have you tried to buy one?
    No, I have a 2019 F3-S that came with the big pulley.
    Active Member Nuke's Avatar
    KNOXVILLE, TN
    In a way, 2RT was correct. I replaced the turn signals on my wife's 2019 F3S with LED's and there is no current way to cancel the hyper-flash. In previous BUDS, there was a setting that allowed the technician to switch the signals into "international mode". This feature has been removed for BUDS II which is on all the new 2019's. BUDS II seems to be a watered down "successor" to BUDS. Boggles the mind... but then again... Canadian engineering.
    2019 F3 Limited , Phoenix Orange Metallic
    Florida Swamp
    Quote Originally Posted by Nuke View Post
    Look into adding load equalizers in the circuit to take the load back to the same as the OEM lights.
    Mar 2017
    Does this method not work?
    KNOXVILLE, TN
    Correct... that method does NOT work on the 2019, nor the 2018 (any of the new style dash with BRP Connect). For the 2018, there was supposed to be a selection in BUDS to put the flashers into "international mode". This toggle was removed in BUDS II (on 2019 models) for an unknown reason. As of right now, there is no way to defeat the hyperflash without load equalizing resistors. I don't want to do this due to the added heat of the resistors.
    Active Member SgtRay's Avatar
    May 2019
    El Paso TX
    "Friend to those who have no friends. Enemy to those who need no enemies. Headache to those who have no aspirin."~ The Phantom Texter
    2019 F3 s , Neutrino Aurora Accessory Fuse Block Blue
    KNOXVILLE, TN
    I wonder if the LINQ system will be compatible with the 2019 F3 Limted?
    Aug 2019
    Stoughton, WI
    I was just perusing the maintenance manuals between the 2018/2019 F3's. I see the 2018 manual shows 5 qts oil with oil/motor filter change, and the 2019 shows 5.5 qts with oil/motor filter. What changed? Different oil pan ?
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    It's quite possible nothing changed... except the manual.
    My Sportster manual called for (as I recall) 3.6 quarts of oil. It kept spitting oil up into the airbox. Later the factory issued a bulletin stating (in essence):"Oops, the oil capacity is actually 2.9 quarts."
