Results 1 to 12 of 12
    Jun 2019
    Pilot Mountain, NC
    Default How do I access the fault codes on my 2017 RTL?
    Check engine light + DPS warning on digital display. Also, I can not shift into first without standing on the brake. Shifting into reverse works.
    Jul 2011
    Mitchell, Ontario, Canada
    Press mode, set and turn cancel buttons. All at the same time.
    Jun 2019
    Pilot Mountain, NC
    Turned on the bike and the check engine light was out. I did the simultaneous press of Mode - Set - main turn cancel button. The screen showed P0000. I figured the DPS had reset itself. Wrong. The next time I powered up, the check engine light was back. Again, Mode - Set - push in turn cancel. No codes were provided.
    Looks like I will be transporting the bike to the dealer on Wednesday (the one and only Spyder Tech is on vacation until Tuesday) and Service says he is already booked up for the week. And, the weather just turned nice in this part of North Carolina. Luckily, I purchased a 3 year extended warranty when I bought the bike in June 2019.
    Thanks anyway.
    GOS member (Girls On Spyders) Spyder_Cowgirl's Avatar
    Bowie, Texas
    The P0000 code is a "blanket" code that, basically, says …"Something went wrong in the CanBus, but I have not a clue what it is." Usually shows up, when there is a glitch in communications. The reason you no longer see the code is it is no longer active -- as you can see from the fact that the lights now behave. I am a bit confused as to why you think the "check engine" light is a problem … are you referring to the engine icon that lights up when the bike is first powered up and then goes out when it starts? Are you having some problem with the bike that caused you to want to look at codes?
    All the best ….. Ann
    __________________________________________________ _
    2016 RT Limited -- "Jubilee" (as in Cherries)
    Guardian Bell (gift from spyderowboy)
    ISCI Dual Flag Mount – Tall Poles
    Lamonster Bottle Holder and Spyder Cuff
    Spyderpops Missing Belt Guard
    Spyderpops Bumpskid
    Spyderpops Rear Run / Brake / Turn LEDs
    Spyderpops Mirror LEDs
    Custom Dynamics HMT Brake
    Spyderpops Keep Out The Trash (KOTT) Grills
    Don't Eat Mud / mudflap
    __________________________________________________ __
    Sep 2014
    USA
    Just for the heck of it check your battery connections. Make sure they are tight.
    Jun 2019
    Pilot Mountain, NC
    After the engine starts, the "engine light" stays lit and the digital warning that shows a DPS problem flashes on and off at the bottom of the screen where the trip meter is.
    Jun 2010
    Las Vegas
    Is your power steering working?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Dec 2008
    Jacumba, CA
    Quote Originally Posted by JO2L View Post
    No one can shift into first from neutral without applying the brakes. That has been a feature of the Spyders since 2008.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Jun 2019
    Pilot Mountain, NC
    I peeled back the frunk liner only to find that the battery access panel appears to be secured by two Torx screws, of which I have none. Do you know what size I need? The manual did not specify.
    Sep 2014
    USA
    May t45. ??
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Go to Harbor Freight. You can buy a whole kit with Torx, Phillips, and some other types for under $5.00 as I recall. That's what I did.
    Jun 2019
    Pilot Mountain, NC
    Thanks all. None of the Lowes Hdwe stores carry it any more. Harbor freight.
