Results 1 to 7 of 7
    Aug 2019
    Florida
    Lightbulb electronics not working
    I have seen cluster problems here but none like mine. I have 2012 rt with 7000 miles only. Bike does start & run but cluster is blank, windshield , turn signals headlight controls, & reverse do not work. Only thing that works on that multi function control set up is the horn. Any help would be greatly appreciated, in my 70's retired & on Social Security only---dealer is way two $$$$$. Thanks
    Default Interesting...🤔
    two things...cluster and command controllers. I would start with a full fuse and relay check and battery connections. If any work was done recently backtrack that work for connections etc. The how and when it started would help.
    ​2012 RS sm5
    Jul 2011
    Mitchell, Ontario, Canada
    Check fuse F1 in the front fuse box.
    2018 F3 LIMITED
    Idaho
    The horn is the only function in that switch that does not use the CanBus. First, check F1 in the left fuse box. If it is good then I suspect the left switch, which uses a processor on a circuit board for its operation, has gone south. That is, unless there is a bad ground in the switch circuit. Does your cruise control work? If not that points to the left switch module since the cc on/off signal goes through the left switch.
    2014 Copper RTS
    Aug 2019
    Florida
    Had not rode it for a couple of weeks--was fine when last shut down. Lives in the garage--no work has been done in last 6 months. Battery is fine as it starts rite up. Thanks
    Dec 2016
    Gold Coast, Australia
    Thought cruise control went through the RIGHT switch block. Thats where the controls are.
    Idaho
    Quote Originally Posted by Fearless View Post
    That's where the buttons are but they connect to the processor in the left handlebar.
    2014 Copper RTS
