Results 1 to 10 of 10
    Active Member sgerksinwi's Avatar
    Jun 2019
    Wisconsin
    Default Passenger Comfort
    I usually ride two up on my spyder.(2018 RT)
    The question is my wifes face is always to close the back of my helmet. Is there a seat that would be designed to help passenger be up higher over . I'm 6-4 and she is 5- 3
    Nov 2018
    Waynesboro, PA
    That is something I think you would need to have made special. Russel or some seat company like that; that make seats to fit each person, they could probably make one like that for you and your wife. I know Russel makes some that are higher and longer in the back for the passenger; by making the back rest a little thinner it gives the passenger a little more room. Good luck with your search for a solution.
    My Spyder
    2012 RTL , Brown
    Jul 2014
    Mint Hill, NC
    One of the things you have to consider and, for liability reasons aftermarket seat manufacturers probably do, is that with such a size difference between you and your wife there is probably a point above which the manufacturer would not consider raising the passenger seat height for fear of upsetting the CG and therefore possibly the handling of the Spyder.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    You can get a thinner passenger backrest. Someone makes one about 1" thinner than stock. Does your wife lean forward a lot? Mine just leans all the way back against the stock backrest. Never had a problem.
    On the other hand, getting your wife to change her ways may not be the best idea. I've learned the hard way it's better to say, "Yes dear."
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Jun 2019
    Wisconsin
    My wife tells me that I lean back to much.
    She wants me to sit
    more upright.
    Maybe a backrest..
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by sgerksinwi View Post
    She wants me to sit
    more upright.
    Maybe a backrest..
    A driver's backrest will certainly help. It will limit her seating room if she is a little on the robust size. I'm trying to be careful how I word this.
    1998 Honda Valkyrie
    US Navy Veteran
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    Ultimate Seats I'm pretty sure when asked they said the passenger would be raised 1 inch that still don't make up the large difference in height between you and the wife.
    I'm 5'9 and my wife is 5' we have the BRP Comfort seat and she says all she can see is my fat head. LOL
    Ultimate Passenger Backrest
    Our passenger backrest is one inch taller than the Can-AmŽ OEM backrest and is sculpted to give the passenger a little more room front to back.
    Our Midrider seat will sit you at the same height and same distance to the handlebars as the stock seat.
    Our Tall Boy seat will sit you at the same height as the stock seat and one and a half inches further back from the handlebars compared to the stock seat. The Tall Boy was designed for tall or large drivers and will help if you feel to cramped with your stock seat position.
    Now you can have the ride you've been waiting for.
    To be continued....
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    My wife had the same problem. She was always looking at the back of my helmet and wanted more room between us. We have had Diamond Custom seats on our last 2 Goldwing trikes, so of course one for the Spyder RTL got ordered. It is made for our weight and leg measurements, and she had an extra 1.5" added to the passenger seat so she could peek over my helmet. The stock passenger backrest was covered in fabric to match.
    Well, the stock backrest was too thick and curved for her, and there seems to be very limited alternative choices. We kept the stock backrest so it can be used if we or a future owner wants to use it and I made a custom backrest for her. I got a stock backrest from a member here and stripped off all the foam, covered it with the seat fabric From Diamond and black vinyl. (pics below) I made a pad from a $5 black foam stadium seat cushion from Walmart backed with the skidplate I had after I replaced it with the LED lighted Spyderpops bumpskid I got at Lamonster Garage. I used a heat gun to mold the skidplate to shape (PPE plastic is easy to heat and mold with judicious application of heat) and glued the stadium cushion to it before covering it with the seat fabric.
    She wanted more support higher up on her back, but I liked the look with the pad about where the stock backrest is. I made it adjustable to 2 heights with a slot and hook type system, and Velcro so it could be tilted forward to clear the trunk lid when it opens. It is in the up position when she rides back there, down when the Admiral seat is vacant.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Nov 2018
    Claremore, Ok.
    I just got a Chrome helmet so she can what we just passed. I do a lot of U-Turns though. But she's usually asleep back there in the twisties and torrential downpours.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Jun 2019
    AZ
    Try a seat cushion under her butt. Very inexpensive and might do the trick.
    2017 Can Am Spyder RT SE6 Limited
    Tri-Axis Bars
    La Monster Longhorn Lights
    La Monster Magic Mirrors
    La Monster Spyder Cuff w/Phone Holder
    Show Chrome Fender Lights
    Show Chrome Backrest
    Show Chrome Brake/Turn Light
    Lid Locks
    2017 RT , White
