Results 1 to 14 of 14
    Active Member tthuss's Avatar
    WARRENTON, VA
    Default Ryker Rally Questions
    I just got my Ryker Rally and I had a few questions, that I was looking for some with.
    1. I noticed that the frunk/glove box area gets really hot. Does anyone have any suggestions on how to help with that? I am not expecting the the heat to go away completely, but was hoping someone had a suggestion on how to help with that, since I would like to use to hold my phone and a few other small things.
    2. Does anyone have any recommendations on locks for the frunk/glove box? I would just like to make it a bit more secure if I put items in there when I am not with the bike.
    3. I am looking for an adjustment tool for the front shocks. I have done some research on here and have looked through the owners manual and the shop manual i purchased, but I was not able to find what size tool to buy. I saw where this tool was recommended https://www.revzilla.com/motorcycle/...ner-wrench-kit. Will this work on the front shocks of the rally? or is there a specific size that I need? or is there a better recommendation?
    Thanks for the help and the recommendations!
    Jan 2017
    Bavaria, Germany
    For a frunk lock look at this thread: https://www.spyderlovers.com/forums/...ker-Frunk-Lock
    Jun 2019
    Florida
    I am not sure if there is much room in the "frunk" for insulation, but you could try some of the thin insulation on a roll that is made with a thin bubble wrap, sandwiched between two aluminum foil sheets. That would take up less space than other insulation. I am not sure how much room there is on the bottom of the frunk container because I have not taken mine out yet. It may be possible to coat the bottom side, rather than the interior. Just suggestions. You can't get much in it right now, so if you took away from the space with insulation, you would have very little left.
    WARRENTON, VA
    Quote Originally Posted by Batmobil-F3 View Post
    thanks for the link, I will def look into this one
    WARRENTON, VA
    Quote Originally Posted by MDLNB View Post
    thanks for the suggestions, I will def look at these as options
    Sep 2013
    Johnson, Vermont
    The front shocks on the Rally can be adjusted by hand. Just take a bit of weight off the front (with a jack) and turn the collar/spring with your hand. I softened mine 1 level (2 I think) from stock.
    WARRENTON, VA
    Quote Originally Posted by Rob Rodriguez View Post
    Thanks, that sounds like it will make it easy to adjust
    May 2009
    Connecticut
    Mine appear to be at the stiffest setting BUT I just went out to the garage and Took a little pressure off the shock to lifting the wheel off the ground and nothing is moving by hand?
    Sea Doo GTI-SE 90 Jet Ski!!
    Nov 2012
    North Las Vegas, NV
    The whole glove box comes out pretty easy, you could insulate the back side. One of these might help for the shock adjustment. https://www.amazon.com/s?k=shock+adj...l_8757akhuok_b
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member Winnex3's Avatar
    Feb 2016
    Paw paw mi
    Quote Originally Posted by tthuss View Post
    maybe try this https://www.amazon.com/Design-Engine...01530774&psc=1
    WARRENTON, VA
    Quote Originally Posted by Winnex3 View Post
    Looks like all I would need to do with that is take the glove box out wrap it underneath and put back in
    Great suggestion
    I'm still new to Ryker so I'm still learning all the Tricks
    WARRENTON, VA
    Has anyone tried this on their glove box? Would like to know how it worked out for you if you have
    Mar 2019
    Ruidoso Downs, New Mexico
    I know this is an old thread but I'm going to try to change my front shock setting. Has anyone else been able to adjust these by hand?
    Last edited by McRuss; 09-26-2019 at 07:37 PM. Reason: not direxcted to the right person
    2020 F3L; gone but not forgotten are all the good miles!
    Sep 2013
    Johnson, Vermont
    Yes. Used a jack to remove some pressure off the front suspension (tires were not off the ground), grabbed the spring and turned by hand.
