Results 1 to 12 of 12
Thread: Need brakes
    Active Member dginoregon's Avatar
    Sep 2013
    Grants Pass, Oregon
    Default Need brakes
    2013 STL after 19,200 miles I need new brakes. How does this compare to others? And cost is going to be $900+ Dealer ship is good mechanic is great, but expensive.
    2013 ST L , Black Current
    Mar 2016
    n.c.
    I got 34000miles and my front pads are still good.Replaced the rear at aprox. 25000. That dealer is a damn thief! AS are most of em. Any mechanic can do it. I did my rear NP....Got the pads from baja rons. LOL@900 BUCKS! WOW.....They should be arrested.
    Jul 2019
    UK
    When you say you need new brakes, exactly what do you need?
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
    Feb 2019
    Portland, Oregon
    Bring it up to Portland, I'll do it for ya and no labor charge. My wrenches are calling me to be used more.
    Who is it in GP or Medford that quoted you that gawd awful price? And do you need rotors in addition to pads? If so, then that's not too bad a price. You must be using your brake pedal as a foot rest.
    Sep 2013
    Grants Pass, Oregon
    They are in Medford. Need everything Pads, Rotors etc... Not sure why I didn't get very many miles out of them? I've had to get on them hard a few times, but other than that? The quote was $300+ for labor $600+ for parts. I have a scraping sound coming from the brakes, but they work fine.
    Sep 2013
    Grants Pass, Oregon
    Wish I knew why I didn't get more miles out of them? thanks for the input.
    Feb 2019
    Portland, Oregon
    That scraping sound can be metal to metal. Not a good thing at all. That's why you need rotors, if that diagnosis is correct.
    If that's a $100/hour shop, 3 hours is about right. Someone with that experience can do it in less time. Could be a flat rate.
    Watch when they do it and request the used parts.
    Quote Originally Posted by dginoregon View Post
    ………….good luck …. Mike
    Bossier LoUiSiAna
    BaJa Ron has the parts &
    : someone offering to getting it done sounds like you got solid solution can’t beat thaty’all enjoy
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Aug 2007
    Greeneville, TN
    Did they give you a reason that you needed 3 new rotors? I'm thinking 1, maybe. But 3??? Seems a bit out there.
    Can you post pictures of your rotors?
    EBC rotors are quite a bit less expensive and of much higher quality. If you really do need rotors, I'd go that direction.
    Feb 2012
    Spring City,Utah
    If you have a bad front rotor, you should replace them both along with both front pads. BTW you wont believe how much of an improvement the EBC pads and rotors are over stock.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Aug 2007
    Greeneville, TN
    If you have 1 bad front rotor, you can replace just that 1 with an OEM rotor. But you DO NOT want to replace just 1 front rotor with an EBC rotor because the EBC rotors stop better and you don't want unequal stopping power on the same axle. Since you can get 2 EBC rotors for just about the same price as 1 OEM rotor. And the EBC rotors are so much better. It makes sense to replace both fronts with EBC rotors, even if you only need 1.
    You can replace just the front rotors with EBC rotors without changing out the rear. I have a good number of customers who have done this and are very happy.
    You can also put an EBC rotor on the rear without changing out the fronts, though I've not had a customer do this.
