Results 1 to 9 of 9
Thread: shaking mirrors
    Jul 2018
    Germany
    Default shaking mirrors
    I need some information..
    After drivin on uneven roads sometimes the mirror will fell off...
    I will order new parts for installation and they have changed something on the original part - but i dont know what kind of change they did.
    Oem part was 705 00 6778/79 and the new item is 705 00 8210/11
    can someone explain it to me..??
    regards
    Reiner
    2014 STS SE5 , circuit yellow (metallic)
    Nov 2018
    Waynesboro, PA
    what year and model do you have? I found the 705 00 8210 and 11 they are the Support Plate Assy. If you are having problems with the mirror being to lose or falling off you may need to adjust / bend the springs back in to shape. The spring will get bent from being take off some time so you have to re bend them back to their u shape. If you look at the last post on this thread you will see what the part is that you have and what a broken one looks like https://www.spyderlovers.com/forums/...ing+clip+video I hope this helps.
    My Spyder
    2012 RTL , Brown
    Jul 2018
    Germany
    I have a 2013er model an the Support Plate Assy has changed into new item.
    705 00 6778 was old - the new is 705 00 8211.
    Does anyone know the difference between the two parts..
    The video shown does not help - the mirrors from the RT are also different
    Reiner
    Nov 2018
    Waynesboro, PA
    If you go to the last post on that link you will see the plate for an ST the first two videos are RT but the last post shows an ST and where the spring clips are and the area that can be a problem and break. The only difference is the part number changed as far as the number go. that will happen from year to year sometime its the same part.
    My Spyder
    2012 RTL , Brown
    Sep 2017
    Durham,Maine
    It's to bad you can't put a set of magic mirrors on that, they work great on the RT!!!
    2012 RTL , Pearl
    Jul 2018
    Germany
    Hello,
    thank you all for your help..
    @CopperSpyder:
    I have orderd the two plates for LH und RH and when theiy are delivered next week i will compare them..
    @Mikey:
    it`s really bad..
    regards
    Reiner
    Nov 2018
    Waynesboro, PA
    Good luck, should be no difference. but one or more of the 3 tabs at the top may be broken on your base plate. https://www.spyderlovers.com/forums/...=magic+mirrors
    Broken tab photo https://www.spyderlovers.com/forums/...2&d=1564940535
    My Spyder
    2012 RTL , Brown
    Jul 2018
    Germany
    It`s me again...
    Yesterday I received the new support plates for my mirrors..
    I tried to find out the difference between the "old" and the "new" version and compared them - there ist no difference.
    Now i have mounted the new items and the mirrors dont shake any longer..
    May be the the clamps (spring in support plate) are tired..
    regards
    Reiner
    Nov 2018
    Waynesboro, PA
    Glad you were able to fix the problem. sometime you can bend the metal u shape springs a little to tighten them up, so you will have a spare set if needed.
    My Spyder
    2012 RTL , Brown
