Results 1 to 20 of 20
Thread: power shift
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    Default power shift
    When I paddle shift from first to second on full throttle at 7000 rpm I get a hesitation, but not in 3,4,5,6 which is quick and smooth don't know if there is a adjustment for it has anyone have the same problem it is on 2019 f3s special series model se6 semi auto
    richie spyder
    That 1st to 2nd hesitation is not an uncommon thing for Spyders, regardless of the motor they're running - maybe it's something BRP did as part of the de-tuning they've done to the engines?!
    Regardless, that hesitation is one of the reasons I got my V-twin 2013 RT's ECU upgraded/enhanced, and others who've got 1330 motors (like yours) have found the same thing & the same solution! An ECU Upgrade might not be something you want to jump into immediately on a brand new machine, but if that hesitation becomes too annoying, you now know there is a solution, and a relatively easy one, albeit not quite what you'd call 'cheap'! But it can really make your Spyder lose that hesitation and get up & boogie from the word GO!! I reckon it's really made mine the Spyder I wanted & thought I was buying from the outset - and it's definitely one of the best mods I've done!
    Sep 2016
    Chillicothe, Oh.
    Between first and second is where neutral is located and I believe this has something to do with the hesitation.
    2015 RT , Black
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by ssmcclub View Post
    When I shift from first to second on full throttle at 7000 rpm I get a hesitation, but not in 3,4,5,6 which is quick and smooth don't know if there is a adjustment for it has anyone have the same problem it is on 2019 f3s special series model
    Why would you want to that "Power Shift" at 7000 rpm in first freekin' gear? If you treat your Spyder like that don't tell whomever buys it from you
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Peter I beg to differ on the " not quite cheap " reference …… back in the day ( way back ) guys would spend multiple thousands of dollars on power increasers and not get near what they can do with our ECU for the money spent….. biggest bang for the buck I think I've ever seen ….. but, jmho …… Mike
    Apr 2013
    massapequa ny 11758
    ok thank you peter on a solution to fix the problem, only tried shifting from first to second full throttle a couple of times at 4, 5, 6, 7, thousand rpm all times would hesitate.
    richie spyder
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Hummmmm, my 18 RTL has neutral between reverse and 1st. Can't get there from 2nd.
    Different tranny's on different models?
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by Valkrocket View Post
    Shift pattern internally for the transmission is R-1-N-2-3-4-5. Neutral between first and second same as most motorcycles.
    2015 RT , Black
    Greenville Tx
    On mine I take it to first and downshift into neutral. Downshift with the R button for reverse.
    2017 F3 Limited
    Greenville Tx
    The big thing that is seldom discussed on the ECU upgrade is the improvement in shifting. There IS a big difference.
    Back in the day we called a power shift what we do to pass. It is not a up shift, it is a down shift and go.
    2017 F3 Limited
    Apr 2015
    Green Bay, WI
    I made a similar post approx 1-2 yrs ago on a 2015 F3's. I don't know why considering all the posts describing the transmission shift patterns-------But on my Stage 2 upgrade of the ECU---the problem is gone & the transmission wasn't touched.
    Thus for some reason the 1st to 2nd gear hesitation that I had with a stock ECU has been eliminated by the stage 2 ECU upgrade. Obviously the arrangement of the gears in the transmission had nothing to do with the delay.. It was in the ECU or ECM --whichever you prefer to name it that caused the problem.
    As to the previous comment --Why would anyone want to power shift--It would be an impossible task for me to explain the logic needed for a Power Shift that has been in existence for over 50 years. I kinda miss that 4 on the floor gear shifter & even the 3 on the column on my 1953 Ford.
    I will go one step more to explain the motorcycles with add-on thumb shifting powered by a air cylinder & solenoid. Flashing the ECU on the 2 wheel motorcycles gave an option to set the "Kill-delay"--wire's going directly to & grounding out the cylinder coils. Mine was set at 50 millisec at 120lbs air pressure--some had theirs set at 45 millisec-with higher air pressure 130-140 psi to the gear lever solenoid. 45 milli sec was close to a sheering gears problem.
    May 2018
    Chateauguay, Qc, Canada
    Obviously the arrangement of the planetary gears arrangement in the transmission had nothing to do with the delay.
    I checked in the parts fiche and there are no planetary gears sets in the 2015 SE trannies.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Nov 2015
    Chardon, OH
    The gearboxes of the SE5 and SM5 transmissions may be the same, but the shift drums are different. Thus the shift sequence of the SE5 is different than the manual. R-N-1-2-3-4-5. I would suspect the same applies to the 6 speed transmission. The operator's manual for a 2015 RT even states that the sequence is different between the SE6 and the SM6. Based on the evidence here, it looks like the delay is more of an ECM / TCM issue than anything else, although in the SE5, it helps to keep the oil level in band.
    Doug
    ”Freedom is not a loophole”
    Apr 2013
    massapequa ny 11758
    I forgot to mention that my spyder is a semi auto model I said it was power shifting , what I should have said I paddle shifter in to second when it had the hesitation,
    richie spyder
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by Eckhard View Post
    I deleted the word planetary just for you--- :-) I was thinking Hayabusa--I had 3 of them. Still have the planetary gear assy downstairs.--duh---SE6 = semi auto trans.
    Apr 2015
    Green Bay, WI
    Your were correct--throttle wide open & pressing the shift lever is "Power Shifting" The hesitation between 1st & 2nd gear is caused by the ECU/ECM "Kill Delay" settings. BRP long delay was on the side of being over cautious .
    Nov 2015
    Memphis, Tenn.
    it won't hurt it
    Sep 2018
    greensburg,pa
    Quote Originally Posted by Revalden View Post
    Called fun - cant hurt the stock motor because it just closes the throttle before it revs to high(torque limiter logic).
    I have a new f150 with the twin turbo 3.5 liter - put it in sport mode switch to AWD and floor it- even the wife loves it and said my 1988 mustang gt couldn't do that!!
    I love the 115 hp from this triple and plan on testing it daily.
    2018 RT-L , Blue
    Mar 2015
    Tacoma WA.
    Let it rev up just a little then just before the 1-2 shift relax the throttle a tad. Works for me!
    2017 F3-S Daytona , Yellow and black
    Apr 2013
    massapequa ny 11758
    ok terry I WILL GIVE IT A TRY THANK YOU
    richie spyder
