Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
  1. #26
    Feb 2019
    Portland, Oregon
    Thank you Freddy and hogr1der for enlightening me about the OEM bolt. I will definitely go that route. I have never torn into that area, and assumed the bolt was a standard item - apparently it's not.
    If I were to go through my dealer, is the price the mentioned $10.49 there too?
  2. #27
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    Should be close to that but for a buck or 2, who cares?
    The best substitute for brains & knowledge is....................silence.
  3. #28
    Feb 2019
    Portland, Oregon
    So I went down to the garage and removed the front sprocket cover and 1. I see what y'all were talking about that bolt with the ginormous flange. Yeah, that's not found at Ace Hardware. 2. The bolt was tight and everything was clean. 3. I will be checking that often. 4. Thanks all for putting up with my dumb questions.
  4. #29
    Dec 2009
    West Oz
  5. #30
    Jul 2019
    UK
    Just thought I'd bring this to the top for an update.
    Rechecked the bolt yesterday after a little over 5000 miles since the repair. Bolt nice and tight and no sign of any movement so it would seem that tightening to 110lbs/ft (ish) has done the trick.
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
  6. #31
    SoFlo
    Quote Originally Posted by PinkRosePetal View Post
    Did you reassemble with lubricant on the splines or assemble dry?
  7. #32
    Jul 2019
    UK
    PMK, go to first post to see the pics.
